Found Radio Code, Still not working - Team Integra Forums - Team Integra
post #1 of 3 (permalink) Old 06-16-2017, 01:19 AM Thread Starter
Hello, first post here. Just got my teg ('98) and the radio was locked. I did some research to take the center console apart so I could find the serial # and retrieve my radio code. Luckily someone had taped a piece of paper to the outside of the radio with the code on it that I found when I started to take the radio out so I didn't have to completely remove it. Anyways I then reset the radio by unplugging my battery and then powered up the car and put in the radio code only to hear a super loud BEEEEEEEP (which I have read confirms I had the correct radio code) but then the radio did nothing else afterwords. The radio shows the little equalizer level bars on the digital display but none of the buttons seem to do anything.
Before I put in the radio code I was actually able to adjust the equalizer even though the radio didn't play any music or change stations, etc. Now after entering the code I can't even adjust the equalizer. or anything
Has anyone had this issue before or have any suggestions were to go from here? Took me a month just to get the radio to beep at me! I don't want to install a new radio if I can get the stock radio to work. Thanks in advance.
Adorable is offline
post #2 of 3 (permalink) Old 06-16-2017, 10:34 AM
Articles: 76
At this point, spend $80 or so on a new radio. It took the code and conformed it with the long beep, but apparently the radio isn't going to do anything more than that for you unfortunately.
I guess you should double check that the radio is getting constant power, which is powered by the 15A fuse in the underhood fuse box labeled "Backup". But if the clock in the dash is working, then this means the fuse is good (the clock and the radio's constant power share the same circuit)
post #3 of 3 (permalink) Old 06-17-2017, 02:15 AM Thread Starter
Thanks. The clock does indeed work fine. I tried to put in one of those cassette to 1/8inch converter adapters and the tape deck spits it back out after making some noise for about 10 seconds. I did see a cable that kind of looks like a MIDI cable behind the deck that wasn't plugged in. there is also a Honda multi-CD thing under the driver's seat that I can't seem to get to respond or anything either.
One more thing I want to mention but I have no idea if it has something to do with the radio.. there is a little silver button underneath the left side of my steering wheel that looks like it was installed after-market. I have no idea what it does and it is not labeled.
Maybe I should just learn to do a dyi stereo installation as you suggest. I got a quote of about $150 from my local stereo shop and I don't feel like paying that much at the moment.
Adorable is offline
