00 ls coupe door wiring - Team Integra Forums - Team Integra
post #1 of 4 (permalink) Old 01-11-2017, 10:33 AM Thread Starter
Hey all,
Traded for the above and the dude who I traded for said there was a window motor problem. He had taken out the L window motor, though I've found there is no power to the switch.
Though something strange, When I push the door lock switch down, the door locks work, though the R window goes down about 3 inches ? Push the lock switch up and window goes up same distance ? This because no power to Window switch, OR the Lock control box in the door causing the problem ?
Anyone have a wiring diagram of the Drivers door ?
Thx 4 any info.
David2000 is offline
post #2 of 4 (permalink) Old 01-11-2017, 11:14 AM
danteisme's Avatar
i should have a diagram at home. if no one replies sooner, i'll check when i get home from work today.
danteisme is offline
post #3 of 4 (permalink) Old 01-11-2017, 07:34 PM
danteisme's Avatar
This is from a 98 integra electrical troubleshooting manual. I dont have a scanner at home so i hope you can zoom in on these. 00 ls coupe door wiring-imageuploadedbyag-free1484181107.613326.jpg
post #4 of 4 (permalink) Old 01-11-2017, 07:51 PM Thread Starter
Update,
This morning, I traced the White wire with red/yellow stripes back to on top of larger black relay on top of the fuse box under the dash. I have continuity from the door switch connector to the top of the fuse box. I would think that it would go to the black relay with 3 connectors rite below it, however No continuity to any terminal. Ran out of time B 4 grabbing lunch n leaving for work so I'll dig deeper 2maro.
Thx 4 the pics, I'll have to check em out on my desktop at home 2maro morn..
