Audio is Fading - Team Integra Forums - Team Integra
 3Likes
  • 1 Post By jjkz24
  • 1 Post By Hamblen41
post #1 of 7 (permalink) Old 01-10-2017, 06:20 AM Thread Starter
Audio is Fading
HELP! I just got my 94 Integra LS about a week or two ago it didn't have a stereo so I installed a aftermarket stereo without a wire harness adaptor. I would be able to listen to the stereo for about 10 minutes then the audio would slowly start to dim out and then cut off but the stereo would still be playing just no sound. And when I would turn on my headlights is would cut the sound off immediately. So I went out and bought an adapter to go to my factory harness plugged the factory back up the way it was suppose to be then connected the aftermarket harness and then the aftermarket stereo and it still does the same thing. I don't know what is going on but I'm really tired of this and I just want to listen to music. I have HID headlight so I thought maybe it was to much power when I turned them on and it cut out my radio but my audio still dims and shuts off after ten minutes without the lights on. I also don't have any subs or an amp hooked to it. Someone please help me.
Hamblen41 is offline
post #2 of 7 (permalink) Old 01-10-2017, 07:53 AM
Welcome to the site.
Two things first, and then we'll get to your issue.
1. You made two threads within the same section. Only one thread is needed. No need to duplicate your threads
2. I changed the title of your thread from "Help!! My stereo is killing me!" to what you see above. This helps other users who might be searching for a similar issue that you're having, with key words within the search bar. Having words like "Help" and "My stereo is killing me" isn't helping other users.
On to your issue.....
Never, ever install a radio without a harness. I mean, you "can", but it's dumb to do so. Wire harness adapters are so incredibly cheap, that it's just common sense to use one. It definitely takes out the equation of a wiring issue when it comes to troubleshooting.
If I were you, I'd grab yourself a multi-meter, and start probing your power wire(s) when the issue occurs. The means that you'll need to have the radio out of the center console, but still connected. Watch your voltage when the problem occurs. After this procedure, we can go to the next step of troubleshooting.
Lastly, have you tried another radio just to make sure you don't have an internal issue with it? If not, find a buddy with one laying around and give it a try.
Mr.Stripes likes this.
post #3 of 7 (permalink) Old 01-10-2017, 08:03 AM Thread Starter
Thanks for the advice I will check it out with a multimeter tomorrow when I get the chance. I also didn't mean to post it twice my phone messed up and I had to restart it so I didn't know if it got posted or not. But I appreciate the help I will also try a different stereo and see what happens. I figured once I bought a harness it would correct the problem but it didn't make a difference.
post #4 of 7 (permalink) Old 01-11-2017, 02:38 AM Thread Starter
New update on my stereo. It sucks because now it doesn't play anything it comes on and then reads amp error after about a minute. I took my good stereo out of my other car to see if that was the problem and that one didn't make sound and read amp error after a minute also. Yesterday while it was playing the speakers made a fuzz noise and then that's when it cut out and started doing this amp error crap. Did I blow out all my speakers or something?
post #5 of 7 (permalink) Old 01-21-2017, 05:24 AM
Did you make sure to wire everything in correctly? It's pretty simply color coated, also make sure no wires are touching any other wires that they shouldn't be touching (exposed wires, etc.). Shrink tubing is perfect for the job but electrical tape will do. How exactly did you wire up the head unit without the adapter? Did you splice into any wires that were not part of the original stereo wiring? I would go back and double check every step you took to wire it in the first place. I would also check the speaker wiring in the doors, are they aftermarket speakers? Could be grounding to metal somewhere along the line.
1990AcuraIntegra is offline
post #6 of 7 (permalink) Old 01-23-2017, 08:01 AM Thread Starter
Thanks for the reply. When I first wired up my head Unit without a wiring adapter I found a diagram online. But then I reconnected all the wiring from the factory harness back together and went and bought an adaptor. I figured that would fix my problem but it didn't. I also don't know if any of the speakers are aftermarket. I know the one in my driver door is because I put that one in. It was missing. I also disconnect the two rear speakers from the head unit to see if they may have been the problem and the stereo worked for a bit and then faded out after about 15 minutes. Also the second I turn on my headlights which are HIDs if that helps, the stereo just cuts out automatically. Everything is still powered just no sound. But after all that even having the two back speakers unhooked in now doesn't have sound at all and just reads amp error after 2 minutes. And I have also tried other headunits and it does the same thing.
post #7 of 7 (permalink) Old 01-23-2017, 09:08 AM
1. What head unit do you have install?
2. Do you have an aftermarket amplifier install?
Can be a short in the speaker lines, speaker or even RCA's (if install).
Under 2 more years left. I can apply for Historic Tags for my GS/VTEC Automatic and no more SMOG
phatintegra is offline
