Obd2 and ECU issues - Page 2 - Team Integra Forums - Team Integra
 2Likes
post #15 of 31 (permalink) Old 08-10-2015, 04:52 PM Thread Starter
So, I need to get the p72-a05, right?
camerartus is offline
post #16 of 31 (permalink) Old 08-10-2015, 05:07 PM
Ick, it probably is not going to be as easy as "slap an ODBII ECU in there to pass".. your car may have modifications to it making the swap necessary..
for instance, I had to go to ODBI because my header only has one O2 sensor spot (+ i needed a tune), I can't throw an II in my car and expect the car to even run (never mind other mods on my car)
post #17 of 31 (permalink) Old 08-10-2015, 08:01 PM Thread Starter
That's a problem in Texas.
Also, I thought the "01" Heard to the car being a five speed manual.
post #18 of 31 (permalink) Old 08-10-2015, 09:13 PM Thread Starter
This also confuses me.
How else can you tell if you have the correct ECU?
post #19 of 31 (permalink) Old 08-10-2015, 09:14 PM Thread Starter
Also, The wiring harness I have is different from the one that was pictured earlier on this thread. I'll upload a photo shortly.
post #20 of 31 (permalink) Old 08-10-2015, 09:26 PM Thread Starter
Where is the one that I have on my car.
post #21 of 31 (permalink) Old 08-10-2015, 10:07 PM Thread Starter
I meant, that is the one I have on my car.
post #22 of 31 (permalink) Old 08-10-2015, 10:35 PM
It's obvious in your pic that you have a conversion harness. The harness are the red connectors, with black wires leading out of it.
You've been told what to look for, you uploaded a pic confirming an OBD1 ECU. I'm not sure why there's doubt. @MorningZ and others have explained as much as possible, what you have.
post #23 of 31 (permalink) Old 08-10-2015, 11:30 PM Thread Starter
The pic I uploaded was different from the one that I was originally shown. I didn't know that red always meant conversion harness.
post #24 of 31 (permalink) Old 08-10-2015, 11:34 PM Thread Starter
Also, I uploaded a link showing that a P72-A01 is a model number that is the same for GSR with a five speed over drive, whether it's an OBD1, or an OBD2 ECU. Honda used that same model number for both.
post #25 of 31 (permalink) Old 08-10-2015, 11:35 PM Thread Starter
"five speed manual drive"
post #26 of 31 (permalink) Old 08-10-2015, 11:37 PM Thread Starter
See attachment.
post #27 of 31 (permalink) Old 08-11-2015, 12:13 AM
Red does NOT always mean a conversion harness. That just happens to be the color of yours. You have an OBD1 ecu. That is why your OBD port does not communicate. Question answered.
post #28 of 31 (permalink) Old 08-11-2015, 01:18 AM
From Hondata:
All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. e.g. 37820-P72-A01
The part number consists of three components:
  • Honda's part number for ECU, which is always 37820
  • Three characters (which are loosely related to the model of car/engine). e.g P72
  • Three characters (which are the revision of the ECU) e.g. A01 or G52
The middle three characters are the most useful to identify what the ECU is. Different generation ECUs may use the same characters. e.g. a P72 OBD I ECU is different from a P72 OBD II ECU. Here is a list of common ECUs:
The last 3 characters are broken down into 3 parts. "A" generally is used for US ECUs. "G" is European, and "J" is Japanese. There are other versions of this, but you get the idea. The second digit "0" typically means manual transmission, where a "5" means automatic transmission, and the last digit "1" is the version number.
If you are automatic, sure. Otherwise you will need manual. If your car is 00-01 it will be the OBD2B variant.
migee is offline
