Power Door locks arent working - Team Integra Forums - Team Integra
post #1 of 32 (permalink) Old 06-20-2003, 05:47 PM Thread Starter
Hey, My power door locks have stopped working, and i have no idea why. My windows still work. Anyone have any ideas? I guess i should take my doors off and look at the wiring...but i dont know if im gonna be able to identify the problem. Maybe my system had something to do with it...
*--AndreA--*
integrachick13 is offline
post #2 of 32 (permalink) Old 06-21-2003, 01:55 AM
Possibly the fuse?
One question from my Mercedes-Benz Test: "What is the primary benefit of a manual transmission?" One of the answer choices: "The driver has an extra pedal to stomp when frustrated."
hpracing007 is offline
post #3 of 32 (permalink) Old 06-21-2003, 01:57 AM
- Does it work from the passenger side?
- Do they make any attempt to move physically?
post #4 of 32 (permalink) Old 06-21-2003, 02:15 AM
I think this has happened before for someone else. If you close your door first then lock them, they should work. If you try locking them while the doors are opened, then they will not function.
In conclusion, doors won't lock while open due to a safety feature.
FS: 16" Gunmetal Ray's Gram Lights Click Here For More Details
Toonamix is offline
post #5 of 32 (permalink) Old 06-21-2003, 04:17 AM Thread Starter
nope both door locks dont work regardless of the door being opened or shut. No power at all they dont even budge. At first it was one door i believe then the passenger door, but i may be mistaken and it could be both at the same time.
post #6 of 32 (permalink) Old 06-21-2003, 04:19 AM Thread Starter
i havent checked the fuses i guess i'll do that tomorrow....anyone know where the door lock fuse is located?
post #7 of 32 (permalink) Old 06-22-2003, 09:59 PM Thread Starter
k i checked the fuses they are all ok. gotta be the wiring
post #8 of 32 (permalink) Old 06-22-2003, 10:05 PM
theres also a module in the driver door.... that may have gone bad (although i have never heard of that being the case)
post #9 of 32 (permalink) Old 06-24-2003, 05:02 AM Thread Starter
really?
post #10 of 32 (permalink) Old 09-24-2003, 02:10 AM
what happend? did u figure it out yet? i made the same post in 3g forms, same problem but my trunk also doesn't work,
FedsEx is offline
post #11 of 32 (permalink) Old 10-23-2003, 10:50 AM
I'm really curious as well. I just bought my integra and the power locks have been disconnected because it wouldn't always work and them sometimes it would apparently lock the old owner out of the car sometimes...
evilempire is offline
post #12 of 32 (permalink) Old 10-23-2003, 11:24 AM
O.K.! These are the things that you need to check. form what I see here is you have checked the fuses. Good! The module in the drivers door is the next thing to check. The module is behind the door panel and is usually a brown box. i have had this problem in my car and I have had to replace the module in the door and that worked for a little while. But I hink in your case you should be good if you replace it. Also something to pay attention to is when and if the locks work intermittantly do they make a grinding or chattering sound. Just form my experience in my car, when i replaced the module in the drivers door the locks began to work again for about 6 months and then the locks started to make the grinding, chattering noises and i was ale to lacate that the problem was in the passenger side lock itself. Troubleshooting this problem can kind of suck but there are alot of people here that will help you through it. Just a FYI the module at the dealerships lists out at 160.22 so you might want to try a salvage yard like I did and make sure you get some sort of warranty. Or if you know someone who also has a teg you could try there module. This would eliminate that problem if that was it. These modules do go bad! Good Luck!
topfuel73 is offline
post #13 of 32 (permalink) Old 12-08-2003, 12:01 PM
my passenger power door lock sticks but stops at a certian place and my driver side has completly stopped working. the only way i can get it to work is if i lock it from the outside with the key. i have an alarm and when i set it, it locks the passeger door but not the driver. its not a secure feeling
INTEGRA! INTEGRA! INTEGRA! my imagstation
kickerguy is offline
post #14 of 32 (permalink) Old 12-08-2003, 12:25 PM
I've been having the same issues with my teg - the keyless entry remote stopped working, and then a few days later, the locks were reacting inconsistently. I've put away the keyless remote for now, and am using the key to unlock/lock the doors. I'm waiting for the spring to get the door panel off to investigate (a lot of stuff to be done with that door off - speaker install, fixing window rattle, replace DHS mirror...)
__ '95 SE stolen and stripped '00 VW Jetta VR6
alchu is offline
