LinkBack | Thread Tools |
#1 (permalink) |
Dome lights, Dimmer switch, Climate Control, and Cruise control dont light up. For the Climate control the upper light parts when you press say for example the rear defroster the green/orange light will turn on but the climate control itself isnt lit up. The dimmer switch doesn't work but my cluster lights are on. The interior light fuse isnt blown. Any ideas?
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Real Name: julian
Model: SE automatic
Year: 96
Could be the fuse......i had prob with my tails not coming on>> running lights......i put a fuse still a no go....took it to my mechanic and h.e tested the fuse ......it looked good but was no good......put a new fuse and there it was ........so just replace it even if it looks good......50 cent fuse can really give u a headache......also the climate control bulbs seem to burn out.......went to junkyard and got a bunch of them from the c.c.......tested them before installing.......but see'n you dont have dome light.....think a fuse to all power to lights inside is gettin turned out somewhere......fuse change could be....also check fuses in the bay also
#3 (permalink) |
I will put another fuse in tomorrow. I just got this car in the trade everything runs fine and etc. Just those two wiring problems its kinda annoying how i cant see anything at night....that dome light and spot light would be amazing. What fuse in the bay would i look at?
#4 (permalink) |
Real Name: Nick
Model: DB8
Year: 1998
You can tell if the fuses are blown by looking at them.
I just replaced the bulbs in my defroster switch and cruise control... now they work! they are special bulbs though. T3's if memory serves, shoehorned into a special socket. you could probably jury-rig it if you had to, tho the bulbs are just a few dollars at the dealer |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
