Factory Power Antenna Wire Colors - Team Integra Forums - Team Integra
post #1 of 14 (permalink) Old 09-03-2009, 08:52 PM Thread Starter
I'm trying to figure out what these wires are off of my factory power antenna. I have 3 wires a solid black, yellow/green & white/red it has a plug at the end of all these wires. I know one is the ground one is the switch power from radio and one turns on when car is on. Car is 1994 its missing the wires that normally would connect to the other side of the plug.
Thanks guys!
ionic_rs is offline
post #2 of 14 (permalink) Old 09-03-2009, 09:02 PM
Black = ground
White/Red = Power
Yel/Grn = wire from the radio telling it to go up/down
post #3 of 14 (permalink) Old 09-03-2009, 09:21 PM Thread Starter
Thanks morningz that was quick!
ionic_rs is offline
post #4 of 14 (permalink) Old 09-06-2009, 04:49 AM
I also have a broken antenna but i dont mind it up all the time. its the grinding noise. im not sure but is it right if i take the grn/yellow that runs down the drivers side cut it and mount it up to a switch in my center console it will keep it up if i have it off? or to replace the motor in the future and be able to keep it down?
thanks
BigMink is offline
post #5 of 14 (permalink) Old 09-06-2009, 11:00 AM
Grinding noise = broken teeth on the mast usually
Whatever position you want it to stay in, just get it to that position and unlug the 3 wire plug that ionic_rs was asking about
post #6 of 14 (permalink) Old 09-09-2009, 05:15 PM
all fixed, just took off some panels at the back and cut the yellow antenna wire, reset radio with the security code and im all set. untill i get around to buying a new motor for it, which is 64.99 cdn . then i suppose ill just run the cut wire to a switch in the center console. thanks stephen for the wire colors really made it easy. took me 15 mins total and its great now
BigMink is offline
post #7 of 14 (permalink) Old 09-09-2009, 05:21 PM
2kdc2's Avatar
Feedback Score: 21 reviews
I'm going to wire up a swtich to manually control my antenna. I know that I must cut the yellow/green wire, but where are the three locations specifically? I was planning to make the cut at the radio harness.
2kdc2 is offline
post #8 of 14 (permalink) Old 09-09-2009, 05:39 PM
where i cut mine is at the back directly beside the antenna motor. all three are in one bunch and are easy to see and cut. i would simply cut it from there and run it under the carpet through the back behind the seats and up to the center console. its very easy, simply extend the wires to a switch which should be a 30 amp 12vdc(any electronics store should have). it should have three spots for wires. two on the bottom are for either end of the grn/yellow wire. the other is for a ground which you can add on to the third spot. simply run the ground to the bolt directly below the e-brake and mount it in the center console in the slots beside the e-brake.
hope that helped a bit. id be more than happy to rip mine back apart and take the pics if you are unsure of anything. just lmk it takes like 2 mins
BigMink is offline
post #9 of 14 (permalink) Old 09-09-2009, 05:46 PM
That's the easiest place to catch it....
It is in the driver door sill wire harness as well, which is easier to get to, but harder to find the exact wire (because there are a few yellow/green, like for the fuel pump)
if you choose the door sill.. make sure you have a volt meter handy to make sure that you have the correct wire, which with the radio off shows 0 volts, with the radio on shows 12 volts.. and MAKE SURE you aren't using the key to turn the radio on/off (use's it power knob/switch/button), because otherwise the fuel pump wire will display the same behavior
post #10 of 14 (permalink) Old 09-09-2009, 05:47 PM
Originally Posted by MorningZ on Sep/03/09
Black = ground
White/Red = Power
More specifically:
Black = ground
white/red = +12 constant
yel/grn = +12 when radio is on, 0 when off.
post #11 of 14 (permalink) Old 09-09-2009, 06:00 PM
stealthpenguin's Avatar
Feedback Score: 13 reviews
Originally Posted by MorningZ on Sep/09/09
Quote: 2kdc2 on Sep/09/09I'm going to wire up a swtich to manually control my antenna. I know that I must cut the yellow/green wire, but where are the three locations specifically? I was planning to make the cut at the radio harness.
I'm planning on doing this as well. I did this on my other deck which was easier since it has a labeled wire harness.
Do you know which wire coming off the back of the factory deck controls the antenna?
stealthpenguin is offline
post #12 of 14 (permalink) Old 09-09-2009, 11:13 PM
Same color as we've been talking about
Yellow with a Green stripe
http://www.team-integra.net/sections...p?ArticleID=74
post #13 of 14 (permalink) Old 01-08-2014, 07:01 AM
Power Antenna Override - Team Integra Forums - Team Integra
Going to resurrect this old thread
If I want to control the height of the antenna like you would use a potentiometer to control motor speed or volume, is it possible to do this with the switch method?
If this is the wiring:
Bk = ground
Wh/Rd = +12 constant
Yel/Grn = +12 when radio is on, 0 when off.
I don't want the antenna fully up or down, just a reasonable height which I can adjust at any time...can this be done with a simple on/off switch because when radio is off it will come down unless you cut the 12v constant altogether.
Can remember the name of the switch but it stays in the middle and you can move it up and down and it will return to center when releases (like a joystick), can that switch be used?
Cheers
theteacher is offline
post #14 of 14 (permalink) Old 01-08-2014, 11:10 AM
No, you won't be able to do that... it's simply "12v up", "remove 12v down"... there is nothing accomplished by varying the voltage
