stage 1 vs stage 3 turbo wheels - Team Integra Forums - Team Integra
post #1 of 8 (permalink) Old 03-31-2005, 12:24 PM Thread Starter
Feedback Score: -6 reviews
sup guys
quick question
what is the main difference,or any difference between the stages of turbo wheels. like when you see a turbo that says stage 1 wheel,or stage 3 wheel. what is the difference? i have a turbo that has a stage 1 wheel,and i heard that if i had a stage 3 wheels,it would be alot better,and i would probably hit higher numbers on the dyno.
tightteg99 is offline
post #2 of 8 (permalink) Old 03-31-2005, 12:36 PM
compressor wheels measured by "trim." what trim is your compressor wheel? it should say right on the turbo.
the turbine wheel is measured by stage. here is something that somewhat explains the differences between some of the stages. click me
"Some muthaf***a's always tryin' to ice-skate uphill" - Blade
Redline94LS is offline
post #3 of 8 (permalink) Old 03-31-2005, 12:41 PM
the turbine goes by stages, and to my knowledge the stage 3 wheel is generally a larger wheel turbine that is more efficient for more air flow. i personally am purchasing a stage 5 4 bolt pattern GT35S, which is the largest turbine available. what is the trim of your current turbo?
pubestripe is offline
post #4 of 8 (permalink) Old 03-31-2005, 01:51 PM Thread Starter
my turbos trim is .70 a/r compressor side .48 a/r exhaust,with a stage 1 wheel
post #5 of 8 (permalink) Old 03-31-2005, 02:04 PM
Feedback Score: 16 reviews
Nice find Redline. That should be able to answer many questions.
tepid1 is offline
post #6 of 8 (permalink) Old 03-31-2005, 06:43 PM
DAMN!!! are you sure it's a .70a/r mated with a .48a/r turbine??!!?? that's a really bad match up. that combo isn't efficent at all.
94 LS turbo'd...15psi = 381whp & 338wtq on 93 pump ~ SOLD SETUP CURRENT: 94 TEG w/ B18C1 MOTOR...all motor sucks balls, and Vtec feels like .05psi of boost.
shermanyang is offline
post #7 of 8 (permalink) Old 03-31-2005, 07:02 PM Thread Starter
well the guy who sold it to me told me that,and then when i got it, the compressor side was stamped .70 and the exhaust was stamped .48 AR.....so im pretty sure thats it. why you say its not efficiant at all?
post #8 of 8 (permalink) Old 03-31-2005, 09:02 PM
Well.. it really depends. there are actually 2 measurements that are used for the .70 A/R. one is the which we all know is the "B" cover that is used for the most part on larger stroked motors with less efficient head, and is in most T04B turbos. The other is the well known "S" cover which is one of the seriously larger flowing compressor wheel covers that support up to about 700whp.
The trim that is really being used is not to be confused with the exhaust WHEEL TRIM. When you see the "trim" that is discribed w/ most turbos, they are referring to the compressor wheel inducer/exducer sizing trim. When you're looking at exhaust turbines, that's when you start looking into "stages". Certain size turbine exhaust wheels have certain measurements that are condensed into categories called STAGES 1-5.. Even larger turbos can have stage III, while smaller ones can have stage1 or 2.
TheShodan is offline
