Straight pipe /Testpipe vs High Flow Cat? - Team Integra Forums - Team Integra
post #1 of 128 (permalink) Old 06-14-2002, 10:40 PM Thread Starter
which one is better. i heard the straight pipe would give you better performance but is not smog legal. does anyone know which one would give better performance? and the straight pipe is cheapter too.
xacurax xracerx is offline
post #2 of 128 (permalink) Old 06-15-2002, 12:30 AM
In terms of performance a str8 pipe is better than a hi-flow cat but ur car will be louder and will not pass emissions tests. Depending where you are there are big fines for not having a cat-coverter.
ITR144 is offline
post #3 of 128 (permalink) Old 06-15-2002, 01:25 AM
Go with the a high flow cat.. More specificly, go with Car Sound cats. They are worth the money. For additional info on Car Sound cats check out the article found here.
Fentoozler45 is offline
post #4 of 128 (permalink) Old 06-15-2002, 06:58 AM
Articles: 40
Take a look at this test of a 2.5" Carsound cat vs 2.5" test pipe on an Integra Type R.
Yeah where's all that test pipe power I've heard so much about?
My conclusion from this, test pipe =
#01-0379
SurferX is offline
post #5 of 128 (permalink) Old 06-15-2002, 08:17 AM
Thats because this Integra is NA, a test pipe on a boosted car will yield hella good performance gains. As far as putting one on an NA car..I have one on my GSR, I did notice a little loss low end, but believe it or not I can definately feel a crazy high end rush. Just to warn you though it is very loud.
GSxRated is offline
post #6 of 128 (permalink) Old 06-15-2002, 08:20 AM
Articles: 40
I think I will go with the printed dyno over your butt dyno unless you can crap out a chart for me.
A test pipe over a stock cat will have some gains, but compare the test pipe to a good high flow cat like the Carsound and it's nothing. Just look at the flow numbers in the cat article, the Carsound is pretty close to it's equal-sized test pipe counterpart.
Turbo or S/C may be able to utilize the slightly higher flow capacity of the test pipe, but I didn't see either mentioned anywhere in this thread, I would think this thread would have been put into our F/I forum then. I'm assuming this is in regaurds to a bolt-ons N/A setup, in which case a test pipe will not outperform a high flow cat.
SurferX is offline
post #7 of 128 (permalink) Old 06-15-2002, 11:30 AM Thread Starter
thanx surferX, where can i look at carsound cats?
post #8 of 128 (permalink) Old 06-15-2002, 11:51 AM Thread Starter
to GSxRated, do u reccoment gettin a straight pipe or a car sound cat? because i cant afford to lose low end power, but my stock cat sux riote now. any suggestions?
post #9 of 128 (permalink) Old 06-15-2002, 12:24 PM
:echoes carsound cat. converter even though he's not GSxRated:
97IGSRVTEC is offline
post #10 of 128 (permalink) Old 06-15-2002, 01:03 PM
Let me put it this way... with a test pipe YOU WILL NOT PASS EMISSIoNS!
Do you want to change your exhaust every year to get it smogged, then put it back and risk getting a ticket becuase you car smells like ass and is polluting the environment?
Or... Would you rather put on a Car Sound cat that flows almost as well as a straight pipe in tests and not have to worry about it for a long, long time?
The choice is yours. Oh, by the way... Have you every been to L.A. (or most other large cities) when the sky is brown from smog and you feel like you are gonna develop Asthma just by looking at it? In case you don't get my drift, smog looks like this:
post #11 of 128 (permalink) Old 06-15-2002, 07:14 PM Thread Starter
lol, ok i get the point. how often do you have to go in for a smog check. i can just keep my old stock cat and put that on evertime i have to get a checkup, that way, I WILL PASS EMISSIoNS.. just a thought.
post #12 of 128 (permalink) Old 06-15-2002, 09:51 PM
Articles: 40
I just noticed you live in California. Do yourself a favor and get the Carsound. The fine for running a test pipe is quite hefty in our state. Police are beginning to do roadside smog checks and if you are caught with a test pipe you will be short thousands of dollars and possibly jail time if the judge feels nasty that day. Kind of seems pointless to me as a CARB legal Carsound cat will perform just as well, not pollute the air, and keep you out of jail. California does not mess around when it comes to pollution and with good cause. I don't understand the idea that your car has to be a gross polluter in order to perform. HyTech's header-cat-exhaust system will outperform any exhaust system out there and it runs cleaner than the stock system...
SurferX is offline
post #13 of 128 (permalink) Old 06-15-2002, 10:03 PM Thread Starter
where can i get a carsound cat?
post #14 of 128 (permalink) Old 06-16-2002, 11:26 AM
MichaelDelaney's Avatar
Articles: 30
gee, I wonder if a search would help you here?
do you think it's covered in the articles?
btw you can get the carsound cat at www.ipsracing.com or from Dave Stadulis of SMSP (email in the cat article) or direct (without flanges/bungs hardware) from Magnaflow/Car Sound.
related thread
MichaelDelaney is offline
