LinkBack | Thread Tools |
#1 (permalink) |
sadly no one in my area carries these plugs and they have to be ordered..
![]() does anyone know another more common plug that will give me equal performance for a supercharged application? FYI: these copper plugs have a heat range of 7 but i have been told by numerous people that I can run heat range 6 for my low boost application (8 psi) are all copper heat range plugs created equal? meaning if i were to put another brand's heat range 7 copper plug in my car would it cause problems?
Milano Red 99 LS - JRSC Equipped and Hondata Tuned We’ve all heard the wisdom that there’s no substitute for cubic inches, but cubic inches of what? Is it cubic inches of engine that count, or cubic inches of air in the combustion chamber? It’s obviously the latter. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
http://www.clubplug.net/
I got my V-Power racing coppers online form these guys. King motorsports sells the VPower racing plugs in all heat ranges as well if you are looking for a reputable place that everyone knows. I would go to an R5671A NGK and see how you like them. I would try a #7 or even a #8 range if your boost is high enough. The other option is to go with an Iridium NGK no. 7 since you are FI. the cost is pretty close. yes the heat ranges are the same across brands for a car model. you know what the heat range means right? |
#3 (permalink) |
Like MD said, I sure hope you know what heat range means because you are not going in the right direction of heat ranges, especially for boost.
Welcome, FlatRate. You last visited: 12-01-2011 at 02:28 PM Private Messages: Unread 0, Total 611 (total 250 allowed.) Your PM box is 244% full. Its been forever since I've been on here! And don't PM me as I intend to keep my box full so I don't get any annoying PM's! |
#4 (permalink) | |
how so?.. i was under the impression that the objective is to run as hot a heat range plug as you can without getting detonation.. i was told the stock heat range for most hondas is 5.. and for low boost applications you can usually get away with a heat range 6 because it is one step colder.. heat range 7 is common for moderate amounts of boost and high boost applications usually use heat rage 8.. am i in correct in saying this? i appreciate the help i am recieving i am just trying to make sure i have the correct information |
#5 (permalink) |
You've got two guys that have had superchargers and we're both telling you're going the wrong way in heat range.
Do what you think is best for your engine.
Hype-R #885 4 sale: J&S $afeguard There is no expedient to which a man will not go to avoid the labor of thinking. -Thomas A. Edison |
#6 (permalink) | |
I didn't want to insult anyone's intelligence on this basic topic but here are the explanations. btw it was my mistake on the reply regarding brands and heat ranges since I forgot about Champion and Autolite plugs which I never have used . I was comparing NGK to Bosch.:
#7 (permalink) | |
Hold up a second man.. im not at all going against your advice.. i just explained what i THOUGHT was how it works.. obviously i am wrong.. so please clarify what plugs you ran when you were supercharged i would never go against trusted advice but you and sak said i was going in the wrong direction but you didnt explain what was the right direction md thank you for the illistration |
#8 (permalink) | |
sak, gvtec.. please explain how i am going in the wrong direction when it seems like i am dead on the money after re-reading md's post about ngk plugs and heat ranges.. |
#9 (permalink) |
NGK BCPR7ES gapped about 0.034"
When you started talking about running a 6, which is stock for the VTEC crowd (NGK PFR6G), you're not running a colder plug and 5 is a hotter plug. A 7 is one step colder. You can run a 6, but the tip-in detonation will show, depending on how agressive your timing is. |
#10 (permalink) | |
#11 (permalink) |
I think the problem here lies in how you stated your question. You used the term "HOT" plug. What you want is a colder plug, NOT hotter. It seems as if your second explaination is going correct that you want a colder plug with more boost.
Neouser had a SC B18b @ 6psi and ran a 8 heat range plug. From what he told me, it didn't have any problems for him. But 7 would be a good starting point before moving any colder. Those racing plugs mentioned are good and cheap as well. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
