Integra gsr Engine build opinions/setup help - Team Integra Forums - Team Integra
post #1 of 5 (permalink) Old 01-06-2017, 09:58 PM Thread Starter
First off, I haven't been working on hondas in quite awhile, so if I miss speak don't be harsh on me. I recently bought a gsr block with usdm type r pistons in it to replace a bad block (cylinder wall damage). I was installing new bearings, and found out the crankshaft and rods appear to be from a LS? I'm not positive, but the rods have pr4 stamped on them. My question is, will this crank and rod setup work ok with the type r pistons, type r camshafts and gsr head? Also the crank is slightly hitting the oil squirters. Should I stick with this, or swap the old gsr crank and rods from my old block? I'm planning to run the engine in the lemons race, so it will be beat on for two straight days all day.
Nick2402003 is offline
post #2 of 5 (permalink) Old 01-07-2017, 12:27 PM
If your going to use a LS rods & Crank in a GSR block. The oil squirters need to be removed. They do sell plug kits for it.
Here is the link to the plug kit
http://www.goldeneaglemfg.com/index....57b5ruto337rl7
2 more years left. I can apply for Historic Tags for my GS/VTEC Automatic and no more SMOG
phatintegra is offline
post #3 of 5 (permalink) Old 01-07-2017, 02:52 PM Thread Starter
I've read that I should balance the crank and add arp studs to the rods. Has anyone ran without doing that? Would it be safe for my application? Not daily, just racing for 7-8hours straight for 2 days.
post #4 of 5 (permalink) Old 01-08-2017, 10:19 AM
never hurts to balance crank, also believe with the ls rods you would be building a stroker kit for our cars. i may be wrong tho.
'93 RS - Spun Rod
'91 LS - Folded Rear Subframe
'95 RS jdm gsr swap on b16 trans - DD
Mikimaru is offline
post #5 of 5 (permalink) Old 01-09-2017, 01:41 PM Thread Starter
I'm going back with gsr crank.
