GSR Timing - Team Integra Forums - Team Integra
post #1 of 13 (permalink) Old 09-06-2008, 09:44 PM Thread Starter
I have read the timing article and I am still confused. Do I time to the white TDC mark or do i time to the RED mark?
98dc2gsr is offline
post #2 of 13 (permalink) Old 09-10-2008, 06:22 PM
the white mark is the TDC mark. time to the middle or the last mark. i personally run more than 18* base timing. but thats what i do, you on the other hand are a differnt person.
are you advancing the timing? using an old style light gun or what>
02' S2000 T4/T67 546whp/336wtq @ 20psi 93 Pump 92' Integra LS - Beater 98' H2B LS 13.93 @ 100.6 SOLD 94' 2.0L GSR t4/t67 SOLD OUT.. -Acura Factory Trained/ASE Certified/ADV L1 Tech
greaseman is offline
post #3 of 13 (permalink) Old 09-11-2008, 02:43 PM Thread Starter
No. I am not trying to advance the timing. I am using a old style light gun. I have just installed the zex kit on my car and was trying to make sure it was perfectly in time. I don't have a hayne's manual and couldn't find a clear answer through searching. I know this is a newb question but I wanted a clear defined answer before I did something that I would regret. (ex. accidently advancing and possibly causing detonation)
98dc2gsr is offline
post #4 of 13 (permalink) Old 09-11-2008, 03:16 PM
Feedback Score: 22 reviews
The upper most white mark is TDC. The other marks represent degrees BTDC. That red mark I believe is 16 degrees BTDC which I am pretty certain is the what the timing should be set to.
I'd have to consult a manual or an article on here for sure.
ScreaminTeg is offline
post #5 of 13 (permalink) Old 09-13-2008, 12:54 AM
The upper white mark should be TDC and the middle mark in the group of three is (red mark) 16 degrees BTDC, the other two marks are 2 degrees either way... So 14 degrees and 18 degrees.
TBOGSR is offline
post #6 of 13 (permalink) Old 09-13-2008, 02:54 PM
Just to add a question, to run lower octane gas do you advance or retard the timing? Which way closer to TDC or higher degrees like 18 BTDC?
Thanks
djrocketodd is offline
post #7 of 13 (permalink) Old 09-13-2008, 03:08 PM
JustinKlemgold's Avatar
Feedback Score: 20 reviews
To run low octane gas, you get a non vtec.
The ECU in a GSR/ITR will automatically retard the timing and decrease performance if you want to put the cheap stuff in.
2012 Mitsubishi Evolution X - 355 awhp / 350 awtq. Stock Turbo
2015 Lexus NX200T - Wife's Daily
2004 Honda Accord EX-L - Daily
JustinKlemgold is offline
post #8 of 13 (permalink) Old 09-13-2008, 04:55 PM
if you want to advance your timing, you better run with either 89 or 93 fuel. because using lower octane gas when advance ur timing in a long term will cause ....(damn, i forgot the freakin' word). Btw, if ur using the old style gun, you can only see 3 marks (if I remember correctly) which are white, black and orange (or red).
Give me a sec! Eating some rice...
vietboy1606 is offline
post #9 of 13 (permalink) Old 09-13-2008, 09:38 PM
what is it with everyone saying "OLD STYLE TIMING LIGHT" what else would you be using?
wicksteg is offline
post #10 of 13 (permalink) Old 09-13-2008, 10:43 PM
Detonation.
GSRev8k is offline
post #11 of 13 (permalink) Old 09-13-2008, 10:46 PM
^thx for the word mate.
post #12 of 13 (permalink) Old 09-13-2008, 10:49 PM
There are 3 types of timing light: dial (advanced), digital and inductive. The inductive is the most simple one and is preferred to "old style gun"
post #13 of 13 (permalink) Old 09-13-2008, 11:02 PM
i gotcha its still widely used to this day i didnt really see the old term in it but i guess it has been around forever lol and to me its one of the most reliable and simple i guess almost fool proof
wicksteg is offline
