98 type r lsd in a 94 gsr man tranny? - Team Integra Forums - Team Integra
post #1 of 16 (permalink) Old 12-12-2002, 11:26 PM Thread Starter
ok so i picked up a type r lsd for 250 bones it is from ajdm 98. first of all will i have to worry about a jdm trany part not fitting in a usdm car. second of all what parts are needed to throw this bad boy in, third how much would one pay to get this done because there is no way in hell that i am going to do this on my own. if anyone lives in colorado and is a master with transmissions drop me an im. but other than that guys help me out. i'm sure the wealth of knowledge you guys have can help me out.thanks
Aaron
blah this shiat is getting tooooooooo exspensive- anyone wanna buy a slightly modded gsr for $9,000?
au-gsr is offline
post #2 of 16 (permalink) Old 12-12-2002, 11:33 PM
Wow sweet man
"the way i see it, your leading two things right now. jack and s$%t, and jack just left town." "10 inches from the apex pylon is 7 inches too many." -watts
DeafNgari is offline
post #3 of 16 (permalink) Old 12-13-2002, 12:12 AM Thread Starter
i worked it out with the guy to pay him in january after i pay rab, first, for the other half of the suspension set up. but anyone?
au-gsr is offline
post #4 of 16 (permalink) Old 12-13-2002, 12:23 AM
MichaelDelaney's Avatar
Articles: 30
Kaaz clutch pack type LSD Install
although this is a clutch type and not a gear type like the Honda, the basics are similar. You'll need a new diff bearing and bearing shims.
Press fit new diff bearing in if needed, depending on the age of the ITR LSD:
Bearing shims and bearing clearance check/install:
MichaelDelaney is offline
post #5 of 16 (permalink) Old 12-13-2002, 02:12 AM Thread Starter
so it would be best to leave it up to a shop if i have to pul the whole thing apart. by the way i saw thta it would cast around 2 bills to have ashop install it with you deleveringhte tranny. how much would it cost them to install the lsd without the tranny dropped?
au-gsr is offline
post #6 of 16 (permalink) Old 12-13-2002, 01:04 PM Thread Starter
anyone in colorado no where a good place to get htis done at? and any other information on the bearings i will needa nd where to get the spacers fot he lsd would be great!!
au-gsr is offline
post #7 of 16 (permalink) Old 12-14-2002, 12:46 AM
Articles: 40
The tranny has to be dropped either way.
#01-0379
SurferX is offline
post #8 of 16 (permalink) Old 12-14-2002, 09:20 AM
Articles: 30
Removing the transmission did not prove to be a problem despite the fact that I was working alone, without a lift or any special tools. With the transmission sitting on my table, I proceeded to take it apart.
The steps to disassembling the Y80/S80 transmission is covered in the Type R final drive installation article.
With the transmission disassembled, remove the stock differential and proceed to remove the ring gear off the differential. Note that the stock Honda differential has reverse rotation bolts holding the ring gear on.
Before putting the ring gear on the LSD, clean off the mating surface with brake cleaner. The ring gear has to be flipped over to fit on the LSD. Make sure the chamfered inner edge of the ring faces downwards....
au-gsr: I thought that was obvious by the pics shown in the article I had linked. no?
post #9 of 16 (permalink) Old 12-15-2002, 01:54 PM
The Type-R differential fits right into the GS-R transmission. You don't have to have the final drive gear from a Type-R, its a straight swap. Oversimplifying, you take the open-differential out, take the gear off of it, put it on the LSD, put the LSD back in. Messing with shims which is for the tapered roller bearing pre-load test is pointless and a procedure Honda stopped using two years ago. You ditch the tapered roller bearing that came stock with your car (which you will have a hell of a time finding replacements for, and when you do, its around 100 bucks), instead replacing it with the roller ball bearing cartridge that Honda has switched to. (35 bucks a side from your dealer. You'll also want new seals) Chances are very likely you won't have to use shims at all. If you do, there's also a good chance that the clearance is far less than the smallest shim they make. That being the case, you can easily locally fabricate shims using 100mph tape, the metal stuff, not duct tape. It's thickness was around .004-.005" which can be doubled up if necessary. Again, this isn't likely. If you want a detailed step-by-step explanation email me at boon_doggy@yahoo.com. Here's some pictures of mine:
Car album
Conecrusher
TheRooster is offline
post #10 of 16 (permalink) Old 12-16-2002, 02:25 AM Thread Starter
will do if you don't mind
au-gsr is offline
post #11 of 16 (permalink) Old 12-17-2002, 03:10 AM
Articles: 5
So that explains the change in bearing in +99'. Thank God I bought the '99 update Helms section for $30 to find a bearing change and new piston ring configuration. It was about as useless as tits on a boy.
Hype-R #885 4 sale: J&S $afeguard There is no expedient to which a man will not go to avoid the labor of thinking. -Thomas A. Edison
Gvtec is offline
post #12 of 16 (permalink) Old 04-18-2006, 05:52 PM
rooster, i Think you should make a little write up of the ITR LSD install into a 94 GSR tranny because thats the next step i need to take. I also heard that my Y80 tranny wont accept the ITR as well as an S80 tranny will. something about the casings being different althought they both could be GSR's.
It would be very helpful to know what parts i would need to buy before i tackled this project. although a writeup would help EVERYoNE on this site as well.
cryder17 is offline
post #13 of 16 (permalink) Old 04-18-2006, 05:53 PM
well.... i just realized how old this thread was...
cryder17 is offline
post #14 of 16 (permalink) Old 04-18-2006, 07:36 PM
Articles: 4
If you have seen the OMNIMAN video, it shoes how to do it. It even explaoins what will fit in which trannies/differentials.
Welcome, FlatRate.
Your PM box is 244% full.
FlatRate is offline
