91 integra fuel pump relay location - Team Integra Forums - Team Integra
post #1 of 7 (permalink) Old 03-21-2004, 05:03 PM Thread Starter
did a search with no luck, where is the fuel pump relay located?
thanks guys
94 unmolested gsr !!:::SURGEON GENERALS WARNING:::!! "THE SURGEON GENERAL SAYS IT IS OK TO SMOKE V-8'S"
MASSIVEINTEGRA is offline
post #2 of 7 (permalink) Old 03-21-2004, 05:05 PM
well in the g3 it's behind the driver's side kick panel..not to sure on the G2's but you could check.
courtesy of Cyrax71 Back from Hawai'i..this sucks.
94OBD1Vtec is offline
post #3 of 7 (permalink) Old 03-21-2004, 09:06 PM
Feedback Score: 21 reviews
The PGM-FI Main Relay is located on the drivers side, kinda behind the coin tray.
Have u done a relay test yet?
1991 GS 4 dr - Sold 1995 gsr 2 dr - Sold 2005 TL - Current
tsqualers is offline
post #4 of 7 (permalink) Old 03-21-2004, 10:12 PM Thread Starter
havent done a relay test yet, give me info on doing it please!!!!!! thanks
post #5 of 7 (permalink) Old 03-22-2004, 01:47 AM
post #6 of 7 (permalink) Old 03-22-2004, 02:05 AM
post #7 of 7 (permalink) Old 03-26-2004, 08:17 PM
Without actually doing this whole testing as the relay is under the dash pannel try this.
Get your buddy to listen if the fuel pump is turning on when you crank the car (but not actually crank the motor over) Just turn key on.. you should hear the fuel pump.
Another trick I learned when my fuel pump relay (also known as MAIN RELAY) died, was Turn key it cranks.. nothing. Turn again.. same thing..
Just crank it on and off a few times and it after about 5 tries it will start. I notice in the heat it got worse.
I think g2ic has an article on how to fix them (by soldering) but they are brand new 75 bux at the dealer (Canadian).
My friends GSR was having a problem with his main relay, we took like 5 from the wreckers.. to my suprise only 1 or 2 worked. Then within a short while they died too. He ended up buying new, which looks like Honda re-designed as it was not exaclty the same as the original one.
Hope this helps.
91teg-ls is offline
