LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Real Name: Kyle
Model: Integra
Year: 1991
That pic is going to be the float. You will need to drop the tank to get to the pump.
Its simpler to drain the fuel out from the bottom of the tank,there should be a drain plug on the side. Everything else is simple and should take about a hour. |
#3 (permalink) |
Anybody use High FLow Performance fuel pumps with their OEM and high performance fuel pumps before? if so, how is it?
http://highflowfuel.com/i-5209461-oe...1990-1993.html http://highflowfuel.com/c-173508-per...uel-pumps.html |
#4 (permalink) |
Real Name: michael
Model: integra
Year: 92
just make sure if your new performace fuel pump is shorter than ur oem one that u slide it to the bottom of the bracket its held on with or your car will act like its out of gas at a half a tank...i changed mine in my old integra a year ago and had that problem.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
