Car died while driving, now won't start.. - Team Integra Forums - Team Integra
Old 02-18-2011, 11:27 AM   #1 (permalink)
Quoted: 0 Post(s)
'91 GS, 62K miles, 5 spd, NO MODS, new cap, rotor and plugs, new fuel filter just 2K miles ago. Car started and drove fine. Just flat-out died. Towed it home w/ a strap. Fuel pump primes, motor turns over but start.
Check fuses. Check fuel pressure. Check for spark.
Other ideas? Link to a check list?
Thanks folks.
freq is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 11:33 AM   #2 (permalink)
91_LS's Avatar
Real Name: Kyle
Model: Integra
Year: 1991
Quoted: 1 Post(s)
Dose it try to start but die right away? Have you checked timing?
91_LS is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 11:37 AM   #3 (permalink)
Quoted: 0 Post(s)
check the timing belt
"I removed every luxury power item on the car rofl. No A/C, No P/S, No C/C, and No ABS, or SRS for that matter hehe. Haven't missed any of it. I may miss SRS if my face smashes the steering wheel but i think i'll be okay." -97lsteggy
envythe1NTEGRA is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 11:37 AM   #4 (permalink)
Real Name: Donny
Model: Rs
Year: 1996
Quoted: 0 Post(s)
maybe your alternator if that doesn't run then the car will have nothing to run on when it on the battery is there to jump it
"When life throws you a curve, downshift and take it hard"
DonnySavyMuth is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 12:10 PM   #5 (permalink)
Quoted: 0 Post(s)
Will NOT start at all but does turn over. Will check timing and timing belt.
Old 02-18-2011, 12:56 PM   #6 (permalink)
IndyGSR's Avatar
Real Name: Mike
Model: GSR
Year: 1999
Quoted: 0 Post(s)
A bad crankshaft or camshaft position sensor can also cause a no start condition. These sensors are located inside your distributor.
ASE Certified Technician
HONDA
- The Power of Dreams
IndyGSR is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 01:45 PM   #7 (permalink)
Quoted: 0 Post(s)
Just my two cents on this.
When people say " I replaced the cap and rotor",Does that mean the whole distrubutor? The internals? Like the coil and ignitor? Just wondering.In 2002 my car just died while driving. pulled over. towed. Mechanic said it was my "ignitor".He replaced that, and hadn't had any problems since 2002. this is not related to my post about "Immediate shut down after start up"
You'll see the "ignitor" in here:
http://www.team-integra.net/sections...cleID=1112Hope this helps
Just keeping it clean!
int3gra07 is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 01:53 PM   #8 (permalink)
Quoted: 0 Post(s)
Aww can someone fix the link? My bad. The copy paste seemed to not work.
Old 02-18-2011, 01:56 PM   #9 (permalink)
91_LS's Avatar
Real Name: Kyle
Model: Integra
Year: 1991
Quoted: 1 Post(s)
Here you go
Old 02-18-2011, 02:01 PM   #10 (permalink)
Quoted: 0 Post(s)
Thanks kyle
Old 02-18-2011, 02:25 PM   #11 (permalink)
964doorgeezer's Avatar
Real Name: Mike
Model: DB8
Year: 1996
Quoted: 1 Post(s)
When mine did the exact same thing, I replaced the igniter first and still no start. I then replaced the coil and voila! Probably one of those, but either figure out which one for sure or replace the coil first because it is WAY cheaper.
964doorgeezer is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 02:29 PM   #12 (permalink)
91_LS's Avatar
Real Name: Kyle
Model: Integra
Year: 1991
Quoted: 1 Post(s)
Just so everyone knows,if the igniter is bad,you can still have some spark,just not strong enough to run the car.
If you have spark but car still don't run after checking fuel,fuse and all,most likely the igniter.
But if you check spark and there isn't any,the coil is bad.
Old 02-18-2011, 02:35 PM   #13 (permalink)
Quoted: 0 Post(s)
Usually when someone says they replaced the cap and rotor, they are usually referring to the "Distributor cap" and the "Distributor rotor." I would check:
- Check the resistance of your ignition coil. You can find the troubleshooting guide in our Articles section.
- Check the charging voltage of your alternator.
- A excessively burnt contact on the ignition switch can cause the vehicle to randomly die (Done this recently on customer vehicle)
- Honda ICM usually starts to fail intermittently due to excessive heat
- Definitely check to see if the timing has jumped any tooth of the cam sprocket (Also done this recently twice on customer vehicles)
- Check the conditions of your spark plugs.
SimplyB18C is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 03:59 PM   #14 (permalink)
Quoted: 0 Post(s)
OK, start with the easy stuff, I assumed it was getting fuel, spark was my concern so I removed the distributor cap and found some "parts". So what's broken here, the cap or the ignition coil?
Thanks again for all the help people!!!!
Security Question
Identity which item is Yellow in the follwoing words: RoadBananaRedHouse
Insurance
Please select your insurance company (Optional)
User Tag List
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
