oil light flashing / blinking / dimming - Team Integra Forums - Team Integra
post #1 of 7 (permalink) Old 08-15-2010, 02:52 AM Thread Starter
I have a 92 integra.
recently my oil light has been flashing, and sometimes it stays on constantly but dim.
I checked the oil and its fine.
I dont have an oil pressure gauge, but vtec always works so based on this im assuming pressure is fine otherwise the vtec oil pressure switch would keep vtec off right? (I know, I know I need a real gauge.)
I just replaced the sending unit
I read that the ICU goes bad and causes oil light problems, I removed it tonight but dont see any visible signs of problems (I'm still replacing the capacitor just in case but I gott wait till tomorrow )
can anyone tell me WHAT ELSE would cause the oil light to blink?
Thanks.
gonzo is offline
post #2 of 7 (permalink) Old 08-15-2010, 04:03 AM
91_LS's Avatar
oil pump might be going out on you?
91_LS is offline
post #3 of 7 (permalink) Old 08-15-2010, 10:07 AM
Dynamite's Avatar
Send a message via AIM to Dynamite
Maybe one of the wires coming from the ICU rubbed on something and is semi-shorting?
Dynamite is offline
post #4 of 7 (permalink) Old 08-15-2010, 06:41 PM Thread Starter
It's official, oil pressure is fine.
I went out and bought a real oil pressure sensor. At idle when warm I have 30 PSI, when I rev it I get up to 85 PSI.
Im not sure what the pressure is supposed to be but I know you want at least 10PSI per 1k RPM so based on that oil pressure seems fine to me.
gonzo is offline
post #5 of 7 (permalink) Old 08-15-2010, 08:43 PM
Does your car have a jumper harness by chance? Reason I am asking is my buddies 99 Civic swapped with a GSR had the oil light doing the same exact thing your saying and it ended up being his jumper harness had a wire loose.
guy_from_nerk is offline
post #6 of 7 (permalink) Old 08-15-2010, 08:52 PM
sgtmillhouse648's Avatar
have you checked the wires going to/from the sending unit?
2001 Honda S2000 - SCCA Solo B Stock
- FailinConcepts Racing
"One of the great things in motor racing is concentration. When I want to go faster I don't drive any faster, I just concentrate harder." - Jim Clark
sgtmillhouse648 is offline
post #7 of 7 (permalink) Old 08-16-2010, 01:54 AM Thread Starter
@guy_from_Nerk: I dont have a jumper harness.
@sgtmillhouse648: I haven't really inspected it no cause its in a got that plastic over it, should I open it up and see if the wire is messed up?
gonzo is offline
