alot of Carbon coming out my exhaust? - Team Integra Forums - Team Integra
post #1 of 23 (permalink) Old 03-11-2003, 02:50 PM Thread Starter
I'm putting off alot of carbon through my exhaust. Is there anything I can check to figure out why?
Nitr01 is offline
post #2 of 23 (permalink) Old 03-11-2003, 03:49 PM
Articles: 4
read your plugs. you might be running rich. also how was your timing? and did you clean your injectors while you had your head off?
**Disclaimer** I offer no explicit or implicit warranty. What you do based on the information I provide is YOUR responsibility. If your car blows up... not my problem. "One test is worth a thousand expert opinions" -Smokey Yunick "Reading truly is the lost art" -TEGGSRB18C1
Jacksont001 is offline
post #3 of 23 (permalink) Old 03-11-2003, 03:56 PM
Check anything to do with the fuel system
Say hello to ASIMO
IntegU is offline
post #4 of 23 (permalink) Old 03-11-2003, 04:09 PM
Articles: 2
Feedback Score: 57 reviews
I would also suggest adding some Regane Fuel system cleaner or, Chevron w/Techron fuel system cleaner. They both work very well.
Furious05 is offline
post #5 of 23 (permalink) Old 03-11-2003, 04:43 PM Thread Starter
I had the fuel injectors cleaned by the local Honda garage when they were off and also the rail. I set the timing after I did the valve lash.
Nitr01 is offline
post #6 of 23 (permalink) Old 03-27-2003, 03:33 PM
Articles: 4
plug wires, distributor, fuel pressure regulator...
How do your plugs look?
post #7 of 23 (permalink) Old 03-27-2003, 04:51 PM Thread Starter
Sorry about the extra post. I'll check my plugs and get back to you.
Nitr01 is offline
post #8 of 23 (permalink) Old 03-27-2003, 05:08 PM
Articles: 4
Josh, you seriously have a problem with your fuel system, I'm not trying to jerk you around. since you can't drive over to my house I can't guess-timate your problem. I want to help you out okay? the plugs will be a tell tale sign if it is all the cylinders or just one. that will allow us to cut the troubleshooting in half. we refer to that as "half-stepping" a fault.
post #9 of 23 (permalink) Old 03-28-2003, 12:15 AM
how about tryin an 02 or make sure your coolant temp sensor wiring isn't all crusty b/c any extra resistance will trick your car into thinkin its cooler therefore addin more fuel i've seen that a few times on bseries eng.'s b/c of the location of the CTS.
vid
1sickLS is offline
post #10 of 23 (permalink) Old 03-28-2003, 12:45 AM
Feedback Score: 18 reviews
how is your idle? Mine was high when I had a carbon problem... the problem was bad ecu wiring.
MyCarDomain All my cars- past and present
meconfu5ed is offline
post #11 of 23 (permalink) Old 03-28-2003, 08:14 AM Thread Starter
Everything about my car is fine. It idles good runs great and is really quiet. I still haven't had a chance to pull out the plugs but I'll do it this weekend.
Nitr01 is offline
post #12 of 23 (permalink) Old 03-28-2003, 08:34 AM
Articles: 4
It only takes a few minutes man!
post #13 of 23 (permalink) Old 03-28-2003, 11:04 AM Thread Starter
When you have the tools it takes only a few minutes I have to go to my dads house. I'll find out this weekend.
Nitr01 is offline
post #14 of 23 (permalink) Old 03-28-2003, 09:44 PM Thread Starter
I took out the plugs and there was oil on 2 and 4. I was also down a half a quart of oil. It never used oil before the valve job. But I also switched to synthetic at the same time. What next??? It blows smoke at high rev
Nitr01 is offline
