Harmonic Balancer Wobbles - Team Integra Forums - Team Integra
post #1 of 22 (permalink) Old 01-03-2007, 02:57 PM Thread Starter
Hey guys im in need of your help, i just got my motor all good to go and running great, except the crank pulley wobbles so much the power steering belt comes off, i know this isnt good at all, i was just wondering would that be a bad balancer? or would puttin thoes 2 washers that are concaved make this wobble so much? any input would be great thanks guys
Acurakid91 is offline
post #2 of 22 (permalink) Old 01-03-2007, 04:25 PM
Is the rubber that separates the middle of the pulley and the outside deteriorated in any way?
Have you tried another pulley?
post #3 of 22 (permalink) Old 01-03-2007, 04:26 PM
Those washers need to be there. They keep your timing belt from getting chewed to pieces.
post #4 of 22 (permalink) Old 01-03-2007, 04:42 PM
JRutski's Avatar
Possibly a missing or damaged woodruff key?
If Acura ever decides to go searching for its soul, it's out in my garage.
JRutski is offline
post #5 of 22 (permalink) Old 01-03-2007, 05:06 PM Thread Starter
hey guys thanks for the qiuck reply, i actually got on g2ic and saw there was a guy with a 93 accord that ahd the same probelm turned out he needed a new crank pulley so ill be gettin that asap thanks for the help guys
post #6 of 22 (permalink) Old 05-10-2009, 09:56 PM
Well I just posted a similiar thread but it got closed so now I have to bring back this old thread. Here is the original post.
Originally Posted by sportsman1539 on May/10/09
I just put my b18b1 motor in my 92 da a couple weeks ago. one of the things I had to do was switch the harmonic balancer from my b18a1 engine on to my b18b1 engine because of the different power steering belt. When I took the one off of my new b18b1 motor, we had to get a breaker bar to take it off. It was on tight. The one on my original motor came off with ease. I switched it over to my new motor and torqued it to 130lbs. Now when the car runs, I can see it wobbling and it even rattles some at idle. When the car revs up, the rattling noise goes away. Is this something as simple as changing the harmonic balancer or could it be something worse???? And when changing it with the engine in the car, how do you keep the crank from moving?? Put the tranny in gear?? Thanks alot
one thing I read that I was supposed to do was put oil on the end of the bolt when installing it. At the time I did not know this and didnt do it. Could this cause it to wobble? Also what does the woodruff key look like?? Its been a few weeks since I changed the pulley and I dont remember what all I did? Thanks
sportsman1539 is offline
post #7 of 22 (permalink) Old 05-10-2009, 10:01 PM
coolhandluke's Avatar
Feedback Score: 39 reviews
one great thread of information is better than two mixed threads with information, which could be one reason(s) the previous thread was closed.
97' ITR Part Out Thread
coolhandluke is offline
post #8 of 22 (permalink) Old 05-10-2009, 10:14 PM
I already know why it was closed. I just didnt want someone saying "why you gonna bring back a 3 year old thread" so thats why I mentioned my thread got closed.
post #9 of 22 (permalink) Old 05-10-2009, 10:19 PM
take the pulley back off and check for the key, if thats there and it still wobbles then it is a bad pulley, end all, just like they told you in your locked thread. god.
boostb2come is offline
post #10 of 22 (permalink) Old 05-10-2009, 10:29 PM
No, they didnt say anything about it being bad, they just said check for the key. BTW, its NOT A PULLEY!!!!!!!!!!!!!!! Its a harmonic balancer FYI! Can you answer this question, what does the "key" look like???
post #11 of 22 (permalink) Old 05-10-2009, 10:33 PM
The OEM crank pulley is the harmonic balancer, so it is safe to say their names can be interchanged.
post #12 of 22 (permalink) Old 05-10-2009, 10:34 PM
HeroOfTheDay's Avatar
Let's keep it mature now... yeesh.
It's an underdrive pulley and a harmonic balancer. Same difference... no need to argue about that.
The key looks something like this:
It's a small rectangular piece of metal, that fits in a cut out key way on both the crank and pulley, which keep it aligned in a certain position. Check to make sure it's there, then make sure you have the concave washers installed around the timing belt gear, and if all else fails, your pulley might be out of round or no longer balanced.
HeroOfTheDay is offline
post #13 of 22 (permalink) Old 05-10-2009, 10:38 PM
Even if the woodruff key is missing, it wouldn't cause the pulley to wobble - the pulley has nearly an interference fit with the crank snout. I'm betting on the elastomer in the dampener has gone to crap causing the pulley to wobble.
my1999gsr is offline
post #14 of 22 (permalink) Old 05-10-2009, 10:49 PM
Thanks for the logical replies guys. I appreciate it. Im beginning to wonder if I installed the key. I dont remember anything about it being on there. It was the first time I had ever replaced a harmonic balancer so I didnt even know to look for that. Is it something that sits on the crank that aligns the harmonic balancer??? I definitely dont remember that if it is. I do remember putting the washer back on but I hope I put it back on correctly.
