Fuel Injector issue on Gen1 - Team Integra Forums - Team Integra
  • 1 Post By sciconf
post #1 of 9 (permalink) Old 02-16-2017, 12:45 PM Thread Starter
Gas is leaking a little on the brown top engine - but car runs fine.
Parts seems not that easy to comeby - which one is the correct part # for 1987 Acura Integra 5 Door LS Auto:
https://www.acurapartswarehouse.com/oem ... 7-661.html
or
https://www.acurapartswarehouse.com/oem ... 7-662.html
Is there a workaround to fix the issue without replacing the unit. I see refurbished units on eBay - changing the o-rings is not going to fix the issue, right?
I once bought a clip on eBay with OEM packaging - it must have been a fake - had to buy it again from dealer.
sciconf is offline
post #2 of 9 (permalink) Old 02-16-2017, 12:53 PM
16450-PG7-661 is the correct part number for your application (the whole injector)
If you have a faulty o-ring that is causing the leak, then yes, you can just replace the o-ring. Again, this is only if the o-ring is leaking/cracked/defective.
If you're just replacing the o-ring, then you'll want:
16472-P10-A01 - O-Ring
AND
16473-P10-A01 - Cushion Ring (injector seat)
post #3 of 9 (permalink) Old 02-16-2017, 01:05 PM Thread Starter
AND
@jjkz24 - thanks indeed
So what is really the different between the 16450-PG7-661 & 16450-PG7-662?
And I need to buy 4 of these? When I buy them, do they come with the o-rings?
I found I had to change most of the o-rings, seals etc - is there a way to figure whether o-ring is bad or not?
How many of these o-rings and cushion rings do I need for each injector?
sciconf is offline
post #4 of 9 (permalink) Old 02-16-2017, 03:10 PM
The difference between both part numbers, is that one supersedes the other. Acura/Honda updated it. The old part number is no longer used
Are all four injectors leaking? If all four are leaking/faulty, then yes, you replace all of them. If only one is leaking, then you replace one of them. If two are leaking, you'd replace two of them. (see the pattern here?)
Yes, if the o-ring is cracked, warped, torn, or otherwise not perfect, then it's bad.
You have four injectors. You'll need four o-rings, and four cushion seats. (again, only if you're replacing all of them)
post #5 of 9 (permalink) Old 02-16-2017, 03:21 PM Thread Starter
If you look at this picture, 21, 5 & 4 - that is why I thought there might 2 o-rings and one Cushion Ring per injector.
https://www.acurapartswarehouse.com/...0-pg7-661.html
On top of the brown engine cover, there is gas near all 4 of them all 4 must be leaking
Update:
With faulty FI, someone's Integra acted weirdly at good speed - mine is smooth - possible o-rings?
sciconf is offline
post #6 of 9 (permalink) Old 02-16-2017, 03:25 PM
#21 is nothing for your specific model
#4 is your o-ring
#5 is your cushion ring
post #7 of 9 (permalink) Old 02-16-2017, 03:28 PM Thread Starter
#4 is your o-ring
Thanks @jjkz24
Appreciate it
jjkz24 likes this.
sciconf is offline
post #8 of 9 (permalink) Old 02-17-2017, 12:30 PM Thread Starter
So if I buy the FI at RockAuto (link below), I need to buy the o-ring and cushion ring separately - no one sells them together - is there a cheaper place than RockAuto?
More Information for STANDARD MOTOR PRODUCTS FJ267
The o-ring etc, if I search on RockAuto, it comes in multiples of different size in one packet - you still need to buy 4 of these?
http://www.rockauto.com/en/moreinfo....482282&jsn=255
sciconf is offline
post #9 of 9 (permalink) Old 02-17-2017, 02:20 PM
Those are really good prices. Do you really want to cheap out on purchasing something as vital as a fuel injector. If you want cheaper, purchase remanufactured units, or find used.
I am not familiar with the brands listed for your o-rings with the link that you provided. I'm only familiar with parts such as OEM from Honda/Acura that I KNOW will fit. You'll need to contact the manufacture of the o-rings that you're looking to purchase, for details on what sizes come with each package.
