First import - Team Integra Forums - Team Integra
post #1 of 13 (permalink) Old 10-31-2016, 11:09 PM Thread Starter
First import
So I recently acquired my first actual car (I'm usually a truck kinda guy) and it's a 1995 integra coupe auto. I got it and I'm going to do a motor swap since it spun a rod bearing. But I have a few questions first.
1. Is it easier to go up or down to take the motor out?
2. How hard is it to pull the motor?
3. What are some precautions I should take?
4. How long should I expect this project to take?
And also when I get the swap done, would it be worth it to port and polish the head and maybe do some port matching as well? Would a header help a stock engine? Or would it just be wasted money
Firstimeimport is offline
post #2 of 13 (permalink) Old 10-31-2016, 11:34 PM
knavekid's Avatar
Welcome to Team-Integra! While I haven't personally removed an engine from one of these cars, I know several members that have done it more than once. I can answer your first question as I have only known of the engine being lifted out of the engine bay. I will leave it to some other members to answer your remaining questions.
knavekid is offline
post #3 of 13 (permalink) Old 11-01-2016, 10:08 AM
Articles: 76
Engine remove: up with an engine hoist
Difficulty level: impossible to ask since no one knows what skill level you have, there is a lot to it.
Something like this would be a good start to understand what is involved
post #4 of 13 (permalink) Old 11-01-2016, 06:11 PM
if you have a shop with a lift, then id go down with the motor. if your at home with a hoist, then go up.
'93 RS - Spun Rod
'91 LS - Folded Rear Subframe
'95 RS jdm gsr swap on b16 trans - DD
Mikimaru is offline
post #5 of 13 (permalink) Old 11-01-2016, 10:44 PM Thread Starter
I have a pretty good knowledge of vehicles but I've never done a front wheel drive anything. And I'll probably be doing it at home with a tree, chain, and my truck with an extra set of hands. I watched that time lapse and I don't think I seen them remove the cv axles. Could someone please clear up the cv axle part for me. I'm assuming they come out until told otherwise
post #6 of 13 (permalink) Old 11-02-2016, 06:18 AM
I always drop the motor down below since I always have access to a 2 post lift. If you don't have access to a lift I would recommend pulling it from the top.
I would get somebody that have done it few times to help you so you can learn.
Remove the axles it will be easier to pull the motor out.
Under 2 more years left. I can apply for Historic Tags for my GS/VTEC Automatic and no more SMOG
phatintegra is offline
post #7 of 13 (permalink) Old 11-02-2016, 10:47 AM
I've done it both ways, with and without a lift. The last time I pulled a motor out (roughly this time last year), it took me and a buddy roughly 3 hours start to finish, with the car in varying states on and off jack stands, using a hoist to lift the motor and trans out. Without diving into step by step details, disconnect all harnesses, heater hoses, throttle cable, etc., remove axles and then can hoist the motor and transmission out together as an assembly. When removing the assembly (motor + trans), just need to have it tilt slightly to clear the shock towers on the way up and in.
13 Ford Explorer (Wifes)
02 HD V-Rod (latest toy)
95 Acura Integra GSR
atkinsonar is offline
post #8 of 13 (permalink) Old 11-02-2016, 11:51 AM Thread Starter
Does the front wheels and stuff have to come off to take out the cv axles?
Would it be a good investment to buy a chilton book or something of the sort?
post #9 of 13 (permalink) Old 11-02-2016, 01:07 PM
I recommend a manual if you're not familiar with these cars. There's enough write ups on the history of this site that it should cover just about any question you'd have (how I learned on mine).
Pulling the axles is pretty straight forward. Pull the wheel, take off the axle nut, separate the lower ball joint, pivot the knuckle assembly up and out (leaving tie rod and upper ball joint attached), and the axle "should" pop out of the hub (may take a little coercion). Then just pop it out of the transmission. Once the axle is out, you can drop the knuckle assembly back in place, loosely snug up the lower ball joint, throw the wheels back on, giving you the ability to maneuver the car if required while the motor and such is out.
post #10 of 13 (permalink) Old 11-02-2016, 03:05 PM
Something I want to add to this. Be careful when putting the axles back you DO NOT want to damage the spline.
post #11 of 13 (permalink) Old 11-02-2016, 07:24 PM
knavekid's Avatar
Download a factory service manual for your Integra here:
Acura Integra 1994-1997
This is a ZIP and the pdf is in the "srm" folder.
knavekid is offline
post #12 of 13 (permalink) Old 11-02-2016, 11:29 PM Thread Starter
Are the cv axles just splined or do the have a master spline and a certain way to go in? I haven't taken anything apart yet as I'm hoping to get the motor swap done in a few days as soon as I get my other motor. I'm sorry if a lot of these questions are redundant but this is my first car and first import so I don't wanna screw anything up. I plan on getting the book for it next time I get paid so I will have that. Do y'all recommend a certain brand of book to get? All I can find around here is chilton and Haynes
post #13 of 13 (permalink) Old 11-07-2016, 05:43 AM
Helms Manual. You can order it online.
