Battery light on and off? - Team Integra Forums - Team Integra
 3Likes
post #1 of 27 (permalink) Old 04-23-2016, 03:55 PM Thread Starter
Okay guys so first off my alternator is 1.5 months old and the belt is nice and tight (lol) , starting 2 nights ago the battery. Light came on, i let the car sit over night and it did not come on the next morning later i drove it for a few minutes and it came on again i reved the engine to about 5k and it turned off for the rest of the day now today it did the same thing after driving for a few the light came on and when i get the engine to about 5k rpm it shuts off and turns on when the rpms drop i drove for about an hour straight with the light off and now i started the car and the light is on again when i rev it turns of and comes back on also the battery is a remanufactured one i replaced it the same day that i did the Alternator, could my alt be going bad? Or am i just f***ed with this car in general
Xjm92x is offline
post #2 of 27 (permalink) Old 04-24-2016, 10:48 AM
What did your voltage say after you measured voltage output of the alternator while the engine is running?
post #3 of 27 (permalink) Old 04-24-2016, 01:49 PM
It'll be very likely fixable, don't fret too much
dudeskee1325 is offline
post #4 of 27 (permalink) Old 04-24-2016, 04:25 PM Thread Starter
So i just got the alternator tested at advanced auto and it says its still good, alt fuse under the dash is also good so im going to get the battery tested
Xjm92x is offline
post #5 of 27 (permalink) Old 04-24-2016, 04:41 PM Thread Starter
Alt is good battery is good the guy at the counter said somthing may be ground out? When i had the car running the voltage at the battery was like 12.5
Xjm92x is offline
post #6 of 27 (permalink) Old 04-24-2016, 05:39 PM
Do a parasitic draw test
post #7 of 27 (permalink) Old 04-24-2016, 05:40 PM Thread Starter
]Alt is good battery is good the guy at the counter said somthing may be grounding out? When i have the car running the voltage at the battery is 12.11 it was 12.53 when he tested the battery at advanced auto also for a while i had a cel for my o2 sensor and i pulled the fuse to erase it and it never came back could the o2 sensor be grounding out?
Xjm92x is offline
post #8 of 27 (permalink) Old 04-24-2016, 05:41 PM Thread Starter
How do i do that?
Xjm92x is offline
post #9 of 27 (permalink) Old 04-24-2016, 05:45 PM Thread Starter
Alt fuse is not blown also i was getting a cel for the evap canister and that never came back either should i start unpluging things?
Xjm92x is offline
post #10 of 27 (permalink) Old 04-24-2016, 07:35 PM
How do i do that?
How to check for and locate Parasitic Draw - Team Integra Forums - Team Integra
Everything you need and more can be found with a search bar...
post #11 of 27 (permalink) Old 04-24-2016, 07:35 PM
Just tackle one thing at a time man
post #12 of 27 (permalink) Old 04-24-2016, 08:00 PM Thread Starter
How do i do that?
That link takes me back the the TI home pages
Xjm92x is offline
post #13 of 27 (permalink) Old 04-24-2016, 08:16 PM
Then search parasitic draw test...
post #14 of 27 (permalink) Old 04-24-2016, 08:57 PM
Search parasitic draw tests as mentioned above.
I would also check and recheck the three primary grounds to make sure those are tight, cables look good, which can affect the whole electrical system in general.
dudeskee1325 likes this.
13 Ford Explorer (Wifes)
02 HD V-Rod (latest toy)
95 Acura Integra GSR
atkinsonar is offline
