OEM motor mounts vs aftermarket stock replacement? - Team Integra Forums - Team Integra
post #1 of 21 (permalink) Old 06-18-2012, 10:44 AM Thread Starter
I searched and could only find after market performance motor mounts.
I'm trying to replace the lower drive side mount and Acura of Peoria has it for $47 and local is 80. I was wondering how an oreilly's one for example would do and if they are just as good, what brand of aftermarket is preferred (advance auto, napa, autozone, oreilly's).
With that motor mount, it's pretty easy to tell if it's bad (the connector parts to the middle are torn). On the top left and right mounts and rear, what is the easiest way to determine? They don't look torn, and i figure since i have the motor out, it would be cake to replace.
Thanks
aznattic is offline
post #2 of 21 (permalink) Old 06-18-2012, 10:58 AM
Functionally the aftermarket OEM style ones are the same. Sometimes you run into a little more difficulty with fitment but it depends.
post #3 of 21 (permalink) Old 06-18-2012, 11:50 AM
stillhere153's Avatar
Feedback Score: 26 reviews
guessing your are talking about the lower compliance/torque mounts
if so I would pick up a hardrace pair ~$80, eBay "billet" $85 shipped, or avid ~$100 + ship
1994 DC4 Slow Drag Build
Testing & Tuning | 626WHP @ 28PSI | 12.738 @ 126.35
stillhere153 is offline
post #4 of 21 (permalink) Old 06-18-2012, 02:44 PM Thread Starter
That's what i'm concerned about. Recently changed an Accord's CV joints, from advance auto, didnt go into the transmission all the way. Picked up a pair at oreillys, went in as soon as i pushed slightly. Quality control is what im after.
Those hardrace look interesting. Any reviews on those in our car?
aznattic is offline
post #5 of 21 (permalink) Old 06-18-2012, 03:11 PM
The hardrace bushing/mounts are good. I've never heard a complaint about them in the ITR crowd who are weekend/road course cars.
98 Integra Type R - Running Log
88 Ram 50 w/4g63t - Under the Hood Video
04 Jeep Laredo
citrus3000psi is offline
post #6 of 21 (permalink) Old 06-18-2012, 08:25 PM
Why not just get aftermarket performance ones and replace all 3. Sure you will get more vibration but you will have peace in mind knowing you have good mounts, not to mention you get a lifetime warranty. I just ordered me some innovative 75a's
NEEK94LS is offline
post #7 of 21 (permalink) Old 06-18-2012, 08:40 PM
^he's talking about the lower mounts
post #8 of 21 (permalink) Old 06-18-2012, 08:55 PM
Ooooo I should read more, my bad but isn't that like a bs mount anyway, I only have 3. Both sides and the one by the firewall.
NEEK94LS is offline
post #9 of 21 (permalink) Old 06-19-2012, 12:40 AM Thread Starter
Well i found out my rear mount is bad, i can't imagine changing it with the motor and transmission still in. I honestly don't want mounts that shake up the entire car. It would be horrible for a daily driver. The hardrace don't look bad, but some reviews say they shake the entire car as well.
aznattic is offline
post #10 of 21 (permalink) Old 06-19-2012, 02:25 AM
FloppyDonut's Avatar
Hardrace owners have compared the stiffness to 60a poly. But unlike poly which deforms after usage, hard rubber reform its shape after long abuse. If you are going to replace your motor mounts with performance mounts, your car will vibrate. How long depends on the stiffness. As far as I know, Hardrace and ES mounts are the least vibrating mounts compares to other name brand performance mounts. I have freshly installed Hardrace mounts and it feels just like my Innovative 60a at 10k miles.
FloppyDonut is offline
post #11 of 21 (permalink) Old 06-19-2012, 09:04 AM
Or you could get OEM mounts for cheap from AcuraOEM parts. I have a thread where I installed ITR mounts in my LS with ES inserts. the ITR mounts are a bit stiffer but still fit exactly the same in my LS Automatic. it shakes my interior but mostly only at idle and/or with AC on. if you arent serious about performance then just get OEM ones... and actually i think that the ITR torque mounts were cheaper than the LS ones.
and yes its possible to change the rear mount in the car with engine still in it. just takes some time and wiggling.
Water leaks fixed for now. Working on getting body back to OEM.
macura2001 is offline
post #12 of 21 (permalink) Old 06-19-2012, 02:56 PM
Da1witskilz's Avatar
Feedback Score: 13 reviews
I used stock replacement Beck Arnley mounts from Rockauto.com. They've held up fine for the last year even though my engine is boosted so I'm sure they're close to OEM quality. I would stay away from the store brand mounts only because I've seen a lot of those mounts fail. Anchor motor mounts also have a very high failure rate.
Unless you want your car to feel like a tractor, I recommend staying away from the polyurethane aftermarket mounts and sticking to OEM replacements.
I think I paid a little under $100 for 2 front lower torque mounts and 1 rear engine mount from rockauto, all Beck Arnley.
Da1witskilz is offline
post #13 of 21 (permalink) Old 06-22-2012, 12:00 AM
1997-2001 CR-V uses the same part#50842-ST0-N81.
It's a dollar cheaper at the local Honda dealer $66 than at the Acura dealer $67.
$15 cheaper at bernardiparts dot com in Boston, Mass.
stlcounty is offline
post #14 of 21 (permalink) Old 06-22-2012, 01:06 AM Thread Starter
I bought the Beck Arnley rear mount from advance auto for 30 (20 off 50 coupon) but they didn't have the lower torque mounts. I seen people not use them so ill probably get the left side at another time.
The Beck Arnley looks like a beast compared to OEM. Still trying to figure out how to get a torque wrench in there to install the rear mount lol.
aznattic is offline
