LinkBack | Thread Tools |
#1 (permalink) |
So i have black soot all over the back of my car(alot!). I am sure it is gas because it wipes off and doesnt smear like oil does. And when i rip it i shoot black smoke at vtec. So i am running rich.
Replaced so far PVC valve Fuel filter o2 sensor fix header leaks Fuel regulator Temp gauge also i rebuilt head so valves and guides where done. Compression is ~215 across the board Fuel pressure at rail is 43 at idle with regulator vac in and out is 54. Any ideas what else i should do? |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
full exhuast i would expect alittle from that but 2 days after washing my car and 50 miles later it is like you spray painted the bumper.
Ya stock ecu but no mods that i feel would need a tune basically stock motor Oem distributor have no idea when cap and rotor was done. Will def do that next Plugs done like 10k ago No cel it idles at about 750-800 rpm and no hesitation. Drives very nicely. Last edited by Trevorc21; 02-08-2012 at 11:33 PM. |
#4 (permalink) |
Model: GSR w/ JDM ITR swap
Year: 1999
You don't have a wideband on the car do you? You sure the car wasn't previously tuned & at WOT/VTEC the map is real rich? I am interested to see what the solution is....
Official Amsoil Dealer, PM me for details!!! *Toxic Fabrications* |
#6 (permalink) |
Real Name: Craig
Model: GS
Year: 1992
I would pull up the datastream on a scan tool and look at fuel trims to see if the computer thinks its running rich or lean. If you have any exhaust leak allowing air into the system before the 1st 02 sensor the computer will richen the mixture when it doesent need to. Or you may find it is actually running rich. Also could be a bad catalytic converter, black suit is common on cars without one at all, perhaps its not functioning properly. Or your 02 could just be old and slowing down, not letting the computer have as tight of control over your fuel trim as it once was. hope something in there was helpful.
When ignorance is bliss, to be wise is folly. |
#7 (permalink) |
Real Name: justYn
Model: GS-R
Year: 1995
Articles: 2
Feedback Score: 18 reviews
have you tried resetting the ecu? sounds odd but who knows
join my clubs N.F.C = No Foglights Club N.A.T.O = No Altezza Taillights Organization wu's turbo build GroundFXMuisc |
#8 (permalink) | |
I have unpluggged the ecu harness and multi times take battery out. Shouldn't that have reset it? Last edited by Trevorc21; 02-09-2012 at 10:58 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
