loose battery terminals - Team Integra Forums - Team Integra
post #1 of 16 (permalink) Old 03-25-2011, 08:18 PM Thread Starter
anyone have a solution for loose battery terminal? i tightened as far as i could before it stripped and i can pull it off with my hand -.-
what material do i use if i were to fill that space in? copper?
20LS01 is offline
post #2 of 16 (permalink) Old 03-25-2011, 08:28 PM
anything thin and metallic is good enough to jam in there...
but the best fix is new terminals instead of trying to hack up the old ones to work
post #3 of 16 (permalink) Old 03-25-2011, 08:39 PM
get a penny and smash it with a hammer to get it more flat "l". then hit the top to give it a curve ")" close to your terminal. that penny will fill in the gap. works great with mine loose terminal issue.
shoua1 is offline
post #4 of 16 (permalink) Old 03-25-2011, 09:00 PM
Just buy a new terminal from your local auto parts store that is smaller. They're only 2-3 dollars
sumfilipinodude is offline
post #5 of 16 (permalink) Old 03-25-2011, 09:31 PM
johnnymass's Avatar
Feedback Score: 23 reviews
I live in redneckville and Ive seen more than my share of nails between terminals and posts. It works but like others have said, replacing the terminals is the best way to do
johnnymass is offline
post #6 of 16 (permalink) Old 03-25-2011, 10:53 PM
toolless terminals are great i had this prob before and i got these for 5 bux just cut off old ones and reconnect the wires and thats it ......easy fix ........replacing is best its a cheap piece of mind
optimalbeing is offline
post #7 of 16 (permalink) Old 03-25-2011, 11:34 PM
racepauly's Avatar
I had this same problem and I used a screw for a few but once my battery needed replaced I bought new terminals. I upgrades to Marine grade terminals since I have my fogs and stereo equipment and alarm all piggy backing on it. Now it works and looks great .
racepauly is offline
post #8 of 16 (permalink) Old 03-25-2011, 11:39 PM Thread Starter
thanks for the suggestions. i actually just squeezed the terminals slightly so it wasnt so round. now its on real tight but it might round itself back with some time.
20LS01 is offline
post #9 of 16 (permalink) Old 03-25-2011, 11:49 PM
Crad008's Avatar
that's what I did with mine, I squeezed the ends together to make an oval then hammered it on the terminal, just temporary until I could get a replacement, but it worked great
Crad008 is offline
post #10 of 16 (permalink) Old 03-26-2011, 04:51 AM
Pocky_Miester's Avatar
I had this problem too but I already had some gold plated multi port terminals from another car so I said screw it and just snipped the wires and replaced the terminals. now I have major blingizzle under the hood lol.
Pocky_Miester is offline
post #11 of 16 (permalink) Old 03-26-2011, 02:02 PM
I had this problem too. You don't need new terminals even know they are cheap. Just take them off and take a grinder with a zip wheel and open up the gap so the bolt can squeeze it more. Done.
sams96integra is offline
post #12 of 16 (permalink) Old 03-26-2011, 02:09 PM
FTFlame's Avatar
cotter pin ftw lol yea mine is doing the same thing...
FTFlame is offline
post #13 of 16 (permalink) Old 03-26-2011, 02:19 PM
91_LS's Avatar
Less then 6 bucks for new ones.
91_LS is offline
post #14 of 16 (permalink) Old 03-26-2011, 02:47 PM
johnnymass's Avatar
Exactly. The reason you can't tighten anymore is because the metal stretched. Grinding a gap so you can tighten it more just means you're gunna stretch the metal further and possibly break the terminal. For the time you spent grinding down the terminal you could've put new ones on. Just my .02
