Clutch disc spring????? - Team Integra Forums - Team Integra
post #1 of 10 (permalink) Old 01-01-2011, 11:27 AM Thread Starter
Out of curiousity what would cause a spring to fall out of the clutch disc assy? I'm in the middle of doing a clutch replacement and found one of the springs had "popped" out. Thanks for any info.
ArnoldA is offline
post #2 of 10 (permalink) Old 01-01-2011, 01:18 PM
defect or failure. Springs should not fall out of a clutch disc. unfortunately, not much u can do about it except replace the disc. unless its brand new i doubt anyone would give a warranty on a consumable item like that.
Riding on rails, low and slow
Project_Teg is offline
post #3 of 10 (permalink) Old 01-01-2011, 01:26 PM
BrandanVenne's Avatar
Feedback Score: 13 reviews
What type of clutch is it. I know Exedy clutches were known for that for a while. I think they corrected it though.
1996 Integra LS SE Sedan Daily Driver
My DB's Running Log
My FS/FT Thread
BrandanVenne is offline
post #4 of 10 (permalink) Old 01-01-2011, 01:51 PM Thread Starter
Not sure what brand but it needed replacement anyway. It's worn down close to the rivets. I'm replacing it w/ an Exedy clutch so I hope they corrected the problem.
ArnoldA is offline
post #5 of 10 (permalink) Old 01-01-2011, 05:02 PM
also, if someone was constantly beating on the clutch, ie. dropping it at 4000rpms, etc... then it could result in that type of failure after a prolonged period.
I'm running an Exedy Stage 1 for last 10k miles and no problems at all.
post #6 of 10 (permalink) Old 01-02-2011, 03:24 PM
drcheap's Avatar
Feedback Score: 42 reviews
Actually, it is actually more common than you'd think. There is a very slight design flaw in the little lips/tabs that hold those springs in place which can cause them to wear down in a specific area, eventually allowing a spring to pop out.
I just read a thread a little while back that did a very good job of explaining this with good pictures and everything. But damned if I can find it again now.
Usually there is some destruction involved, so if yours came out of it okay minus one spring then you are ahead of the game
>insert signature here<
drcheap is offline
post #7 of 10 (permalink) Old 01-02-2011, 04:11 PM
coolhandluke's Avatar
Feedback Score: 39 reviews
I'l try and dig up the picture of my clutch from December 09'. A 2'' part of the metal enclosure broke out and released a spring.
97' ITR Part Out Thread
coolhandluke is offline
post #8 of 10 (permalink) Old 01-02-2011, 04:56 PM
91_LS's Avatar
Hear is a thread on HT about it, it seems to be an ongoing thing. From what i understand,this happens if the clutch pressure plate forks on one side gets weaker,or a hyper extending clutch or the TOB ear breaks can causes the clutch to engage sideways.
And pics
91_LS is offline
post #9 of 10 (permalink) Old 01-02-2011, 06:01 PM
91_LS's Avatar
91_LS is offline
post #10 of 10 (permalink) Old 01-03-2011, 01:04 AM Thread Starter
That looks just like my old clutch disk, LOL. Installing the tranny sure is a PITA when you're by yourself. Tried to muscle it in but no go. Busted out the engine hoist and that made it a piece of cake. Just have to fill her up w/ Redline MTL and she should be good to go. I also changed out the starter contacts, installed new brushes in the alternator, new drive belts and oil pan gasket too.
ArnoldA is offline
