Engine suddenly died on a highway - Team Integra Forums - Team Integra
post #1 of 11 (permalink) Old 09-04-2010, 06:47 PM Thread Starter
Hey, would anyone know what may have broken down?
I was driving on a highway doing 110km/h (70mph), then suddenly I lost the power and my speedo fell to 0.
once I got her towed home, I found no spark and no smell of fuel when cranked.
Im blaming dizzy at this point. Anyone experienced anything similar
Its a 2000 Special Edition (obd2b)
with no electrical or fuel modifications
Thanks!
vzatonsk is offline
post #2 of 11 (permalink) Old 09-04-2010, 06:52 PM
Sounds like a broken timing belt. Pull the valve cover and look.
post #3 of 11 (permalink) Old 09-04-2010, 06:56 PM
thats what i was thinkin too meltman how many miles on the car and whens the last time you had it changed
jdmteggy22 is offline
post #4 of 11 (permalink) Old 09-04-2010, 07:22 PM
You say no spark or fuel.so 1st things 1st. do you hear your fuel pump turn on.maybe invest in a fuel pressure guage if you havent already(its helped me exclude fuel pump problems in a matter of seconds).
xhpnotiqx is offline
post #5 of 11 (permalink) Old 09-04-2010, 07:37 PM
coolhandluke's Avatar
Feedback Score: 39 reviews
Definitely do this first. I'v seen some crazy timing belt issues in the past year. After you have confirmed the TB and timing I would check your battery voltage (alternator) and try swapping distributors.
97' ITR Part Out Thread
coolhandluke is offline
post #6 of 11 (permalink) Old 09-04-2010, 08:30 PM
probably the coil or ignitor...the weak links of 90's honda.
20LS01 is offline
post #7 of 11 (permalink) Old 09-04-2010, 11:13 PM Thread Starter
The timing belt is fine and the engine turns over. I can hear the fuel pump as well, after crank for a good few minutes I started to smell fuel out of the cylinders (too spark plugs out), but still no spark. Can a CKP sensor in dizzy shut me down like that?
vzatonsk is offline
post #8 of 11 (permalink) Old 09-05-2010, 01:51 PM
if you lost power i would suggest it may be an electrical issue....
i was driving on the highway once and all my speedo went crazy and my engine died in gear my turn signals wouldnt blink right, and i pulled over to the side of the road and my car caught on fire lol.
it was a small fire i was able to blow it out, easily once the car was off. turned out a wire from my subwoofer fell out of the fuse, so i had a live wire hanging from my battery and it touched my axle, thus creating havoc.
point of the story is, my engine died when that happened, so if you lost power and your engine died.... just a guess
xCommandoRandox is offline
post #9 of 11 (permalink) Old 09-05-2010, 02:24 PM
most likely the ICM in the dizzy.
PB in my built beast gsr: 10.4 @ 143 C16 30PSI
SEARCH "95DC2TEG" ON YOUTUBE FOR VIDEOS!
PB in my stock long block boosted LS: 12.2 @ 113mph 17lbs 307whp/283tq
Antman985 is offline
post #10 of 11 (permalink) Old 09-07-2010, 04:46 PM Thread Starter
replaced dizzy. Running again
Thanks for help
vzatonsk is offline
post #11 of 11 (permalink) Old 09-07-2010, 05:17 PM
Good to hear man!
DCsquad #14
SSBPGSR
BrokeDC2 is offline
