Everything inside the car is wet - Team Integra Forums - Team Integra
post #1 of 9 (permalink) Old 02-26-2010, 08:39 AM Thread Starter
I'm talking...the whole damn thing. Granted ... it has been raining/snowing a lot recently but still? passenger floor, driver floor, rear floor, REAR SEATS!!! trunk. any help?
nomoreavril is offline
post #2 of 9 (permalink) Old 02-26-2010, 10:10 AM
Articles: 11
well, making a thread on the forum certainly won't magically fix the problem.
normally one would try to locate the source of the leak whenever they have a leak...
if you don't know where you should start, try to search for "leak" and go from there.
there are 3 common possible leak with the integra.
- sunroof and trunk (related to drain tube)
- window frame (damaged weather strips)
- a-pillar/firewall (due to rust)
so, try to locate your source and go from there.
go from area that is most wet.
codenamezero is offline
post #3 of 9 (permalink) Old 02-26-2010, 11:31 AM
when my tail light gaskets were leaking, the water from there made it all the way to my back seats, saturating them with water (they're basically sponges). Try removing your rear interior panel and see if water is leaking in through your tails. I don't know about the driver floor, but a common passenger floor leak is due to the front windshield cowl seal failing.
RiSK is offline
post #4 of 9 (permalink) Old 02-26-2010, 11:48 AM
Tail lights, moonroof drain tubes... these are big points of entry for lots of water.
post #5 of 9 (permalink) Old 02-26-2010, 12:03 PM
Feedback Score: 16 reviews
make sure ur not driving around with a little pong in ur trunk so make sure u lift up cover and check it out. before i fixed my drain tubes i used to have ma whole passenger side front and rear soaked but i cleared out drain tubes nd resealed everything and also ma trunk cuz had leakes from gasket and now my car stays nice nd dry... a little musty but thats a problem for another day.. like when it gets warmer out .....
PaNdAmOnIuM is offline
post #6 of 9 (permalink) Old 02-26-2010, 08:17 PM
Super BunchaNumbers
tony4311's Avatar
In the mean time do you have a garage and a dehumidifier to start drying it out? May want to buy a bunch of arm and hammer fridge baking soda boxes to help soak up the moister. Just keep one in the car after it's dried as much as you can.
Do me a favor.From now on don't care what other people think about your car. Do what YOU want to your car. Who gives a damn what other people think about it.
tony4311 is offline
post #7 of 9 (permalink) Old 02-27-2010, 09:48 AM Thread Starter
i believe i have a dehumidifier in storage. or maybe its a humidifier. haha i dont remember. i've definately got some arm and hammer. good ideas thank you. i should be getting some new taillights in today(doing the crystal red) so when i replace them i fill find if its the taillights leaking.
post #8 of 9 (permalink) Old 02-27-2010, 11:27 AM
take your front seats out, take out the center console, take out back seats, remove spare and rear cargo cover. Get a shopvac, spend a couple hours getting it as dry as possible. Then get 2 or three fans, hook them up and let them go for the rest of the day.
Check on the car periodically to see if its working. Personally when this happened to me, I put two small fans under the carpet after I had gotten most of the water up.
DO NOT THINK THAT THERE IS NO WATER UNDER THE CARPET!!!! check first, cause chances are the carpet got so saturated that there are puddles underneath.
WTB: stock intake set up for 1999 LS. Please PM me if you have one! Speak softly and carry a big stick
gofastgokart99 is offline
post #9 of 9 (permalink) Old 03-03-2010, 12:25 AM Thread Starter
thanks for all the help guys. for now i will try to vacuum/soak it all up. i just make some "custom" taillights, and when i pulled out the stockers they weren't sealed properly at both the seam of the two plastics and the foam gasket(there was water everywhere) on the passenger side. so hopefully this was the source and the oNLY one and it will stop. we shall see.
