distributor oil leak - Page 2 - Team Integra Forums - Team Integra
post #15 of 22 (permalink) Old 05-23-2010, 06:35 PM
Feedback Score: 12 reviews
did anyone figure this problem out, cuz i am on my second o ring in 2 months and its really starting to piss me off. i am going to see if acura has any TSB's on this tomorrow. i also hondabond the hell out of it and it still leaks
Exclusivity Creates Prestige
zodiac_00 is offline
post #16 of 22 (permalink) Old 05-23-2010, 07:48 PM
I had the same problem before I did a rebuilt. I changed all my gaskits, o rings ect.
OGGONZALEZ is offline
post #17 of 22 (permalink) Old 07-09-2010, 04:44 PM
Hey guys, for the ones with the o-ring leak on the dizzy, is the oil collecting under on the bottom bolt holding the dizzy cap on? I've searched multiple times and I cant pinpoint the leak, and i wanna fix it before i change my oil.. Its definitely not coming from the block. I'll get pics up asap so hopefully someone can help me on this
zrk808 is offline
post #18 of 22 (permalink) Old 07-09-2010, 05:40 PM
What I do to finf leaks is pressure wash the area then keep a close eye on it that way u can tell exactly where its coming from
1995 integra gsr Suspension Mods: skunk2 pro s coilovers, skunk 2 front and rear strut bars, asr reinforcement it, skunk2 lcas, Engine mods: skunk2 stage 1 cams, dc sports header and exhaust, new oem lost motion assembly, blox cam seal, hasport mounts
z28nck33 is offline
post #19 of 22 (permalink) Old 07-09-2010, 06:24 PM
^ I degreased the whole area and after a 12 mile drive i check and oil collects oN the bottom side of the dizzy, and the electrical wires located right under the dizzy seem to be oiled a little. Weird thing is when i take off my cap there is no trace of oil coming from inside. Its very confusing because there is no oil on the transmission just on the electric wires and the underside of the dizzy. Ima snap a few pics.
I'm going to get a o-ring for the dizzy, and even if it does not solve it will remove one possibility
zrk808 is offline
post #20 of 22 (permalink) Old 07-12-2010, 06:50 AM
hey guys i did a test to find out further where this leak is coming from. It seems that the oil is coming from the dizzy cap bolts down. I researched and is it possible for oil to be leaking from there because of the o-ring? I would think that it would leak closer to the head. Does leakage from the cap mean i have a faulty distributor??
zrk808 is offline
post #21 of 22 (permalink) Old 07-27-2010, 12:31 AM
When replacing o ring do u have to drain oil
ricketkm is offline
post #22 of 22 (permalink) Old 09-01-2010, 06:04 AM
so I bought a whole new dizzy brand new but I am still getting leaks..
ricketkm is offline
