Axle keeps poping out> Help! - Team Integra Forums - Team Integra
post #1 of 13 (permalink) Old 05-26-2009, 03:22 AM Thread Starter
So my passenger axle decides it wants to keep poping out of the tranny. why?? why? why?
today it did it over 12 times.
i changed this axle 4 diff times already.
there cheap autozone axles, but my old 94 ls teggy never had this problem.
my car is A 1995 integra gsr. any help please T.I members.
Thanks in advance.
Tron is offline
post #2 of 13 (permalink) Old 05-26-2009, 03:32 AM
Incorrect axle???
"Without pain, without sacrifice, we would have nothing"
Blaze360 is offline
post #3 of 13 (permalink) Old 05-26-2009, 03:35 AM Thread Starter
im using 94 axles from autozone. there the same correct?
Tron is offline
post #4 of 13 (permalink) Old 05-26-2009, 04:43 AM
Make sure you have the right seals in there. Mine kept popping out when i swapped a civic si tranny in cause it still had the civic si seals.
"Press any key to continue" Where the hell is the any key???
B16aRS is offline
post #5 of 13 (permalink) Old 05-26-2009, 05:16 AM Thread Starter
i'm sure it does. cause i never changed them in the first place.
also when i brake. i hear. and feel a clicking, knocking noise too, and i dnt know if thats from my brakes or tranny axle problem...
Tron is offline
post #6 of 13 (permalink) Old 05-26-2009, 09:49 AM
few things to check:
The little "C" clip at the end of the axle may need to be slightly "spread out"
Or your diff is jacked up
Or you're not getting the axle completely seated. Should see NO SHINEY AXLE between the tranny seal and axle seal. The seals should basically touch.
post #7 of 13 (permalink) Old 05-26-2009, 10:27 AM
Did you inspect the axle before putting it in? If not you're gonna have to take it back out and take a look at the axle spline to make sure the C clip is there and that there is no damage. Take pics with your phone and upload to photobucket and post them here if you find something weird looking.
tony_2018 is offline
post #8 of 13 (permalink) Old 05-26-2009, 10:35 AM
Feedback Score: 21 reviews
I know one member had even replaced the c-clip with a thicker one to get his to stay..
If it still pops out then you might have damaged the inside of the diff..
Is it a stock diff or a LSD?
95 Integra Ls BG-33P
Check out my 400hp LS-turbo Build
13.3 @ 114 mph
95integraLS003 is offline
post #9 of 13 (permalink) Old 05-26-2009, 11:01 AM
This info right here is incorrect, oem part numbers for both b16 transmissions and acura integra ls/rs/gs transmissions (probably even gsr and type r but I didn't check for those) are the same. If you went and got an tranny oil seal from pepboys/oreilys/autozone/napa please make sure the part number is the correct oem replacement and no thicker or different.
post #10 of 13 (permalink) Old 05-26-2009, 11:32 AM
First AutoZone axles=cheap crap. Are you sure you're getting them in all the way and the C clip is in good shape? If it is knocking and makng noise then I bet that the axle isn't in all the way because it would make noise if it is longer than it should be indicating that it isn't fully in the tranny. Hold the axle straight and take a big rubber mallet and hit it until you her the click. A new axle especially is difficult to put in by pushing it with your hand.
Check the Thunder Grey Teg 1988 Toyota Tercel (1500cc of pure muscle!) Traded in for a.... 1994 Integra LS (Currently has a 1999 JDM ITR engine and tranny) Sold to buy a.... 2005 Acura TL Navi 6 Speed Manual
Airplan727 is offline
post #11 of 13 (permalink) Old 05-26-2009, 05:43 PM Thread Starter
Yeah i made sure the c clips was there. so you are able to bent the c clip out a bit? i never tried that.
so yesterday i just got me a oem rebuilt axle off craigslist.
its in great shape with c clip and all.
so after i take my old one out. i will inspect both.
Tron is offline
post #12 of 13 (permalink) Old 05-26-2009, 05:58 PM
integradude18's Avatar
Yep I had to put a bigger c-clip in mine, now no more popage
also i have an obx lsd.
integradude18 is offline
post #13 of 13 (permalink) Old 05-26-2009, 07:02 PM Thread Starter
im sure mines a not lsd. just a 95 gsr
Tron is offline
