My car won't start. No lights, no Horn - Team Integra Forums - Team Integra
Old 03-21-2009, 08:20 PM   #1 (permalink)
Quoted: 0 Post(s)
Okay, I got up this morning and drove like 30 miles or more to have lunch with my grandma and family. We spent about 4 hours inside the restaurant. When we left, tried to start it and nothing happend; no clicks, not beeps for the door being open, no horn, no nothing. Literally nothing works, Not even the brake lights.
I checked to make sure the battery cables were connected and they were, resulting in disappointment
My aunt jumped my car and it started up, but my ABS light stayed on and now my car sputters. I took the highway back home and during the drive it seemed as if the car was gonna die when it went from 2nd to 3rd, but didn't. It wasn't like a rolling die, it felt like it wanted to stop! Like it was trying to brake on me.
As soon as I got home (30 miles away) I turned it off and literally tried to turn it back on and it wouldn't. I checked the oil, made sure the intake was on right, everything I checked seemed functional.
Except this time, the door open beep worked, but as soon as I tried the horn, everything stopped working again.
Specs on my car
1994 Integra with 89k Miles
Same Alternator since birth
Battery was replaced 2 years ago with an Optimum Yellow Top
I braked pretty hard avoiding an accident on the way to the restaurant.
Automatic Transmission
Replaced Starter 1 year ago.
It has slow starts here and there.
Thanks for the help, and any assistance is appreciated
*edited to fix grammar*
deus_heart is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 08:31 PM   #2 (permalink)
Banned
Quoted: 0 Post(s)
Put it Digital Multimeter on the battery and tell us what you get so that we can for sure rule out the battery. -Aaron
theivjackal is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 08:40 PM   #3 (permalink)
91_LS's Avatar
Real Name: Kyle
Model: Integra
Year: 1991
Quoted: 1 Post(s)
some people dont have a Digital Multimeter. So try to jump the car and if the car starts up disconnect the battery and if the car still runs the alt is good and the battery is bad.Also chick the wires on the battery and clean them if dirty
91_LS is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 09:04 PM   #4 (permalink)
Quoted: 0 Post(s)
Sounds do'able! My question is this though, if the alternator was bad, I wouldn't have been able to drive home for that many miles would I?
So, since I drove that distance, it has to be the battery right.
Also, someone tried stealing my car like a year ago and left all my components on until the battery died. Meaning I didn't realize a crime was attempted until the following morning.
So, did the battery life significantly drop?
Old 03-21-2009, 09:10 PM   #5 (permalink)
91_LS's Avatar
Real Name: Kyle
Model: Integra
Year: 1991
Quoted: 1 Post(s)
you can have a bad alt and still drive on just the battery, but it might just be the battery. do the testing 1st
Old 03-22-2009, 12:28 AM   #6 (permalink)
steelmatt6's Avatar
Real Name: Matthew
Model: Vogue Silver Integra LS
Year: 1999
Quoted: 21 Post(s)
You should see if the Optimum is still under warranty. As expensive as they are, it should have come with one. Try getting another battery assuming it's covered, and see if that works. Or you could get your alternator tested. The downside? If you have to replace the alternator, if a warranty does not exists, and you will need another source of transportation! But is sounds like a simple fix. Do you have a factory alarm, aftermaket alarm, or no alarm at all? Because on my car, if you try to jump start it, it freaks out and nothing works unless you reconnect the negative terminal. once the negative terminal sparks, my cars alarm wails and everything works again.
My Running Log
"For God so loved the world that he gave his only begotten son, that whoever believes in Him shall not perish, but have everlasting life" John 3:16(NIV)
steelmatt6 is offline   Reply With Quote Quick reply to this message
Old 03-22-2009, 12:34 AM   #7 (permalink)
Quoted: 0 Post(s)
I think you can take your car (if it's driveable) or just the battery it and the alternator tested for free...
Want Automatic Windows and Sunroof? Click here!
LSDriver98 is offline   Reply With Quote Quick reply to this message
Old 03-24-2009, 02:34 PM   #8 (permalink)
Quoted: 0 Post(s)
So I took my car in to get the battery and the alternator tested. When I arrived they said they can't test it because they need the car to turn back on after they shut it off.
I got frustrated at this point and just took it to my shop.
After a couple of hours they said that my ABS unit had shorted and the pump kept running and drained the battery. The ABS unit was broke and they needed to fix a relay and wiring on the ABS unit.
Thus fixing my problem, but they recommended I replace my battery because it can no longer hold it's charge since it's been drained more than once.
Alternator is fine.
The repair ended up costing me $1100 because they sold me on a transmission flush, power steering flush, Tiebar bushings, alignment and oil change. All which I could have waited on, but I took the bait.
Anyway thanks for you help guys
Security Question
Identity which item is Yellow in the follwoing words: RoadBananaRedHouse
Insurance
Please select your insurance company (Optional)
User Tag List
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
