Oil pan bolts came loose - Team Integra Forums - Team Integra
post #1 of 12 (permalink) Old 01-23-2009, 06:33 AM Thread Starter
So yesterday it was pretty cold at my house, like 27 degrees. I had ice covering all of my windows. I started the car and turned the heat and defrost on so by the time I left for work it would be melted. I went to back out of the driveway and I noticed an oil burning smell. I stopped and got out and noticed a puddle in the driveway. I didnt have time to look at it so I parked it and drove my other vehicle. Came home last night and there was still some daylight left so I went ahead and jacked the car up and started it. There wasn't anything obvious dripping yet and then it got me in the face. I looked to see where it was coming from, looks like the oil pan, WTF! I checked the bolts, they were all loose and missing two bolts and two nuts. Just wondering if this has happened to anyone else?
drkvltprls is offline
post #2 of 12 (permalink) Old 01-23-2009, 07:24 AM
Feedback Score: 40 reviews
Sounds like someone didn't torque down the bolts properly. I've never heard of them coming loose unless they weren't torqued properly to begin with. You may want to pick up a new gasket (like $20 from the dealer) and some Hondabond and make sure you torque everything down to spec and in the proper order. If you have a Helm's, look at the procedure for it. If you need a hand (or a torque wrench), let me know and I can help you out. I also have a Helm's if you need the procedure for it.
"If it's not worth doing right the first time, it's not worth doing at all." - Berkley Stringer (R.I.P. 7/30/2010)
PureTeg89 is offline
post #3 of 12 (permalink) Old 01-23-2009, 07:55 AM Thread Starter
I think I'm going to pick up a helms this weekend as well as a gasket. Thanks for the offer on the torque wrench but I have one. As far as someone not torqueing the bolts down properly it must have came from the factory like that cause they haven't been touched since I bought the car new.
post #4 of 12 (permalink) Old 01-23-2009, 12:03 PM
Banned
Vibration. You wont beleive the shit that our little four-bangers will wiggle loose. Also when installing my header/Exhaust i noticed i was missing one but all the rest were good so i guess you could say its happend to me...kinda.
97lsteggy is offline
post #5 of 12 (permalink) Old 01-24-2009, 12:03 PM Thread Starter
Alright guys I'm in a bit of a pickle. I got all of my parts except for one gasket. I need the gasket that goes between the header and the downpipe. I went to the auto part store and all they list are o-rings. I even went to the acura website and thats all they list too. Is my aftermarket header weird that it has a gasket or will the o-rings work? The flange is not recessed to accept an o-ring. My car is sitting on jack stands so I need advice quick!
post #6 of 12 (permalink) Old 01-24-2009, 12:09 PM
Banned
i sealed mine with high temp RTV gasket maker untill i could get a real gasket. It worked like a charm too just do that untill you can find one.
post #7 of 12 (permalink) Old 01-24-2009, 12:12 PM
orangebarius's Avatar
what probably happened is the gasket is shot and has been leaking for a while and getting oil all over the bolts. they have loosened up over time. i remember when i replaced my oil pan gasket, most of the screws were oily and very easy to remove. just replace the gasket and torque the bolts and you should be fine.
2003 Sebring Silver Honda S2000 (current) 1994 Frost White Acura Integra LS (sold)
orangebarius is offline
post #8 of 12 (permalink) Old 01-24-2009, 12:40 PM
rebar71's Avatar
^ x2
I would have to tighten my oil pan bolts and nuts every time I changed my oil and I was missing a couple too. There was a tiny bit of seepage - but not enough to actually drip on the ground between oil changes. I went ahead and pulled the oil pan when I changed the oil last weekend and the gasket was shot. It was all dried out and hard - not unexpected after 10+ years. It's all good as new now. A nice new soft gasket will exert some pressure back on the bolts and keep them tight.
rebar71 is offline
post #9 of 12 (permalink) Old 01-24-2009, 12:56 PM
Articles: 2
Pretty clear case of a gasket gone wrong or incorrect torque specs.
*UPDATE 9/5* 500hp Turbo Build, for the love of god no 56k please King Motorsports Tuned: 433whp/300wtq @ 17.5psi - 93 503.13whp/372wtq @ 30psi - 110 Octane
Danny50 is offline
post #10 of 12 (permalink) Old 01-24-2009, 01:32 PM
Articles: 8
Feedback Score: 33 reviews
Yeah wherever you took the car, don't go there anymore. That's a pretty big multi-part mistake.
TheGSRGuy is offline
post #11 of 12 (permalink) Old 01-24-2009, 01:32 PM Thread Starter
I think everybody didnt read my last post. I need the downpipe gasket. I have the oil pan gasket.
post #12 of 12 (permalink) Old 01-25-2009, 02:56 AM
drcheap's Avatar
Feedback Score: 42 reviews
Quote: drkvltprls on Jan/24/09Alright guys I'm in a bit of a pickle. I got all of my parts except for one gasket. I need the gasket that goes between the header and the downpipe. I went to the auto part store and all they list are o-rings. I even went to the acura website and thats all they list too. Is my aftermarket header weird that it has a gasket or will the o-rings work? The flange is not recessed to accept an o-ring. My car is sitting on jack stands so I need advice quick! I think everybody didnt read my last post. I need the downpipe gasket. I have the oil pan gasket.
I believe the o-rings they list are the correct part.
>insert signature here<
drcheap is offline
