b18c1 obd2 in 95 ls, tach prob. - Team Integra Forums - Team Integra
post #1 of 24 (permalink) Old 06-17-2008, 12:39 PM Thread Starter
I know this is probably a common problem.
I have an obd2 b18c1 from a 00 gsr into my 95 LS shell.
Running p72 obd1 gsr ecu.
Using obd2 gsr engine harness.
My tach will not work, I've heard others with the same problem.
Some people say run a wire from the distributor to my tach wire on driver side.
Others say that this gives inaccurate reading, and makes needles jump.
Anyone know what the problem is or know of a fix? thanks.
IshbOO is offline
post #2 of 24 (permalink) Old 06-17-2008, 12:46 PM
the gauges between obd1 and obd2 are interchangeable, all you have to do is swap the green film behind the cluster.
btw obd1 is 94-95, not 94-97
boridragon02 is offline
post #3 of 24 (permalink) Old 06-17-2008, 12:46 PM
i believe you have to swap the green film on the back of the cluster... ie, put the 95 film on the the 00 cluster...
although you may run into a problem as i do not know if the green films are engine specific, so your 95 film may only work with a b18b engine... its not too hard to swap them so i'd give that a shot
"Hellaflush wheels are more aggressive than Vin Diesel and Chuck Norris put together. I'm surprised they don't reach out and punch you while they roll on by."
thunder2709 is offline
post #4 of 24 (permalink) Old 06-17-2008, 12:48 PM
thought so, but are they b18b, b18c interchangeable?
post #5 of 24 (permalink) Old 06-17-2008, 12:50 PM
Originally Posted by IshbOO on Jun/17/08
Also the tach is not working with the ls cluster, I need to know which wire to the ecu needs to be there for the tach, it may have been snipped or cut. anyone know where i can find wiring diagrams for ECU and Cluster?
this info can be found in the articles section, though i THINK its a blue/white wire(not sure been a while since i read it)
im at work so i cant check but i think its here...
link
post #6 of 24 (permalink) Old 06-17-2008, 01:09 PM Thread Starter
alright found the tach wire from the behind the tach. now i just need to find it by the ecu. the guy who owned it before me has so many loose wires and such by the ecu its a mess!
IshbOO is offline
post #7 of 24 (permalink) Old 06-17-2008, 01:16 PM
sgtmillhouse648's Avatar
Good luck! I personally hate dealing with other people's electrical work outside of one person and he's the one who taught me everything I know...neatest kept electrical boards on any robot you'll ever see! I had to rewire my entire hatch when I got the car, and some of the crap people pulled was rediculous!
Good luck
Malhon
2001 Honda S2000 - SCCA Solo B Stock
- FailinConcepts Racing
"One of the great things in motor racing is concentration. When I want to go faster I don't drive any faster, I just concentrate harder." - Jim Clark
sgtmillhouse648 is offline
post #8 of 24 (permalink) Old 06-17-2008, 01:19 PM Thread Starter
thanks
I did find this
http://www.phearable.net/tech/wiring/pinouts2.htm
It is a p72 pin out. obd1.
which is for the tach RPMS? is there another name for it? MAP Sensor?
thats the only thing not working on my cluster.
IshbOO is offline
post #9 of 24 (permalink) Old 06-17-2008, 02:29 PM Thread Starter
found it. looks like i gotta run a wire from the distributor to my tach... Since the obd2 engine harness is being used. thanks everyone. took some searching. but then again people still says it doesnt work.
reasoning.
obd2 engine harness is being used. wire is not in correct spot. I must find out how to get the tach to work!
IshbOO is offline
post #10 of 24 (permalink) Old 06-17-2008, 02:32 PM
Banned
Feedback Score: 21 reviews
umm i realized i bought a obd1 cluster. i swapped my green film over to the gsr cluster from my auto ls obd2. the gas gauge moved up near full. i know for a fact i do not have anywhere close to near full. maybe less than half. before my gas gauge was a little over half.
so im guessing the only way to find out is to fill up gas huh?
Styles109 is offline
post #11 of 24 (permalink) Old 06-17-2008, 02:38 PM
reasoning.
just for shits and giggles, what happens when you plug the OBD2 cluster in without swapping the green film? Since the engine is OBD2 and the cluster is OBD2, would they by chance work together?
Malhon
post #12 of 24 (permalink) Old 06-17-2008, 02:44 PM Thread Starter
IshbOO is offline
post #13 of 24 (permalink) Old 06-17-2008, 02:46 PM Thread Starter
Malhon
No, no needles move, and lighting is messed up. turn signal lights dont work ect. its just messed up. lol
IshbOO is offline
post #14 of 24 (permalink) Old 06-17-2008, 02:55 PM
popanollie's Avatar
okay, ive done this b4 to my friends car, it was a 98 ls and we swapped in a 98 gsr, we used a 98 jdm type r ecu, but had to run one wire from the vtec selonoid to the ecu, since its not infront of me i cant tell you off the top of my head the pin number on the ecu for vtec or the wire colors. we used the same gauges fromt he car the gsr motor came from, and there was still a problem. i think it was the tach and gas gauge wires were reversed on the gauges compared to the stock dash harness. hope this has been some help
popanollie is offline
