LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
OK... Read a little on immobilizer. Sounded like it might be a problem. I do have the key and ignition from the 2000 GSR also, so would it work if I use the ignition and key from the 2000 GSR on the 98??? Will I also need the guage cluster from the 2000 since it has a key light/display in it or will the 98 cluster work if I use the 2000 key/ignition. If it is easier to bypass it on the ECU I would rather do that so let me know.
Issue/task: 2000 GSR have front damage so moving everything to 98 GSR shell.... |
#4 (permalink) |
Real Name: Devin
Model: DVPsshhhhh
Year: 2000
It might be cheaper/easier to find a 96-99 GS-R ECU. Don't forget, the harness' for the ECU's changed in 2000 so you'll need a conversion harness as well.
#6 (permalink) |
Feedback Score: 25 reviews
I dont think that 1998 integras have immobolizers
and that it consists of more than just and ecu and a key. dont bash me if im wrong (i used the words i think, not I Know)
DO IT ONCE .... DO IT RIGHT 94 GSr: Rest In pieces > Just put the B20vtec heart in a EJ ' 95 LS: new build Autox DD
#8 (permalink) |
I believe that Jose is right, this was taken from an article here. read on.
So from what i gather. No the 2000 p72 will not work as a striaght up swap out for your 98 The purpose of this article is to show you how to read the identification labels on ECU's and also how to distinguish between OBD1, OBD2a and OBD2b ECU's. Below is the identification sticker you will find on the side of the ECU. There are three parts involved in reading the identification sticker. They are as follows: A. This is the model number used for EVERY Honda ECU, no matter if you have an Integra, Civic, accord, etc. That number will always be 37820 and come first on the sticker. B. This is the most important part. This identifies the model and year. Down below is a list of all Integra USDM ECU's. C. This is the revision number. I believe all models have at least two different revision numbers. This is simply the version of that ECU that you have. In the picture above you will notice everything is the same besides the revision numbers. P75-A01 was in a 94 LS while P75-A04 was in a 98 LS. I contacted Honda and they stated the main differences between the different revisions were upgrades or enhancements to the motherboard or the chips due to stricter emissions regulations, etc. Note that some ECU codes are available over more than one generation (OBD0, OBDI and OBDII), therefore it is important to identify the ECU connectors as well as the ECU code. Here are all the ECU's found in Integras: P61 92-93 OBD1 GSR P72 94-95 OBD1 GSR P72 96-00 OBD2 GSR P73 96-00 OBD2 ITR P74/75 92-95 OBD1 LS/RS P75 96-00 OBD2 LS/RS PG6 88-89 OBD0 (all models) PR4 90-91 OBD0 LS/GS PR4 92-93 OBD1 LS/GS How to tell apart OBD1, OBD2a, and OBD2b ECU's: How to tell them apart by looking at the clips: Look on the back of the ECU. OBD1 ECU's only have three receptacles while OBD2 ECU's have four. (one of these four is never used.) Now the OBD2 ECU pictured is version "a". The difference between version "a" and version "b" is the order of the plugs. If you look at the picture you notice the first one is used, the second one is skipped and the remaining two are used. on version "b" of OBD2 ECU's the first three are used and the last one is not. If you plan to do an ECU conversion this is important because things will not work if you have the wrong one. I believe all 99 and up Integras have version "b". As for OBD0 ECU's, its real easy to tell them apart because the clips are completely different then OBD1 and 2. on the back you have a green plug, a medal partition, then two black plugs. Hope this helps everyone. Feel free to PM me if you have any questions. |
#9 (permalink) |
Just try to do away without spending any unnecessary $$$.
Well, how about this... If I transfer the whole harness/ecu from the 2000 GSR to the 98 there should not be any issue running it right. If I go this route, will I need to also move the key/ignition over to overcome the "immobilizer" issue??? Please let me know. |
#11 (permalink) | |
#12 (permalink) |
First: I have the key, ignition switch, ecu, wire harness and everything from the 2000 GSR. Are you saying that in order for this to work on the 98 GSR, I still need a conversion harness from obd2a to obd2b??? I have a complete 2000 GSR to pull whatever is needed to the 98 to make it work.
To be honest, I've done a lot of other stuff but never really look at how the harness is connected on the ECU so I may really be better of to just get an obd2a. Another questions: Will ITR obd2 p73 work in my 98 GSR??? The reason I ask is because some one has it for cheap. Many thanks.... |
#13 (permalink) | |
#14 (permalink) |
I would just convert to obd1, the conversion harness is like $75 cheaper, the ecus cost the same, you dont have to worry about your second o2 sensor going out, and you can get your car tuned later down the road if you want to put more mods. (note: converting from obd2>obd1 only consist of only the harness and ecu)
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
