How set ignition timing on my 94 gsr - Team Integra Forums - Team Integra
post #1 of 11 (permalink) Old 02-21-2007, 12:58 PM Thread Starter
I just got the car and I am not familiar with these engines. I checked the timing and it was really retarded so I read the article on advancing the timing. But the problem I have is I have no more adjustment left at the distributor and its still not in the correct range. I estimate it is at around 11 BTDC.
Now from what I gather that process is either for the fine tuning of the ignition timing or bypass of the computer's settings.
How is the ignition timing initially set?
Thanks
Adam
akreider is offline
post #2 of 11 (permalink) Old 02-21-2007, 01:42 PM
Feedback Score: 20 reviews
Originally Posted by akreider
I am pretty sure I found the answer to my question. To adjust the timing more I have to remove the distributor cap and then remove the screw holding the rotor and adjust that. And then go back and fine tune adjust it by rotating the distributor.
Does this sound correct or am I missing something?
Thanks
Adam
Adam, no need to start a new thread, just update the ones you have, also, it takes some time to get the threads approved so please just be patient.
DeadLock23 is offline
post #3 of 11 (permalink) Old 02-21-2007, 01:57 PM
Are you sure the ECU is jumped out correctly? The ECU will try and maintain the correct timing which may keep you from reaching your goal.
beanMosheen is offline
post #4 of 11 (permalink) Old 02-21-2007, 02:17 PM
CJ
Do the steps in this article before checking timing.
Also wait until the car is warmed up.
[RED][SIZE=3]Integraless[/FONT][/FONT]
CJ is offline
post #5 of 11 (permalink) Old 02-21-2007, 03:10 PM
there should be a jumper connector under the trim on the right side of your glove box(should be a blueish color). you need to jump the 2 pin harness with a paper clip or the honda connector. that will set your ecu into base timing mode(abd will show any DTC's that you may have. which will enable you to set timing correctly. if your dist. is fully advanced i recommend immediately moving it back due to the fact that you will be running way too advanced, could cause serious engine damage. let the car warm as stated before for best results. the ignition specs are 16deg. +or- 2deg BTDC...
I
WhtDC4turbo is offline
post #6 of 11 (permalink) Old 02-22-2007, 11:03 PM Thread Starter
I followed the steps in the article, jumped the 2 pin harness with a wire and I also had my car warmed up when I checked it.
Also I forget to mention that as the car warms up when driving, it the response and power drop as to compared to when it is cold. That is one of the reasons that led me to check the timing.
Thanks
Adam
Oh sorry about the extra post I knew I wasnt going to be on for a little bit and just wanted to update the post with more information. Its always easier to answer a question with a throrough description.
akreider is offline
post #7 of 11 (permalink) Old 02-23-2007, 01:13 AM
Your timing belt may be off a tooth. Pop the valve cover off and check the cam gears in relation to the crank.
post #8 of 11 (permalink) Old 02-23-2007, 08:49 AM
Feedback Score: 21 reviews
As bean said..check the timing marks on the cam gears and the crank pully. Make sure all of the marks line up otherwise it won't matter what you do.
havokgroup.com is offline
post #9 of 11 (permalink) Old 02-23-2007, 02:44 PM Thread Starter
Ok I will go out and check that today and let you know how I make out. Thanks for your help.
Adam
akreider is offline
post #10 of 11 (permalink) Old 07-23-2007, 12:16 PM
i set my ignition timing on my 94 gsr to 20deg about a year ago. im reading this now and see about jumping the ecu b4 doing the timing. i checked my timing at it is still at 20deg. did i really need to jump the ecu?
eddienitrous is offline
post #11 of 11 (permalink) Old 07-23-2007, 02:21 PM
yes
DC Squad# 606
Rickdaddy is offline
