P1359 CKP/TDC Sensor Connector Disconnect - Team Integra Forums - Team Integra
post #1 of 4 (permalink) Old 02-01-2007, 12:57 AM Thread Starter
P1359 CKP/TDC Sensor Connector Disconnection
Does that mean the sensor is bad or should I replace my distributor or what? Or maybe I just need to reconnect something? The car still runs just fine.
Having a bit of trouble figuring out what to do. It reads on the sensor as a 'misfire' code, though I'm not noticing any misfiring.
zerosorcerer is offline
post #2 of 4 (permalink) Old 02-01-2007, 01:10 AM
Articles: 8
Feedback Score: 33 reviews
Check the sensor and wiring for obvious problems, i.e. disconnected, frayed, loose, etc.
TheGSRGuy is offline
post #3 of 4 (permalink) Old 11-12-2007, 04:43 PM
i have the exact same issue with my 98 integra gsr.the code came up as a 1381 one though. But it means the exact same thing. The shop i took it to said tolook for bad wires or connections but icant see any and i have messed with it for about 6 hours now and the code keeps poping up. The told me that water or oil inside the distributor could mess it up and that its a very common problem with hondas and acuras. My best suggestion is to just buy a new distributor. That way you know that you've fixed the problem. If anybody else has other sloutions please let me know because distributors are not cheap.
wallyaceGSR is offline
post #4 of 4 (permalink) Old 12-20-2008, 08:47 PM
I just pulled the same code on my car just a couple of days ago, it only started to have issue's as soon as the temp out side got very cold. From reading online it could be a good amount of things that could be causing that code to pop up, like the timing,IAC Valve,Flywheel, and as others have said, wiring and or the distributor.
[ UPDATE ]
The problem turned out to be the second wiring harness that run's off the positive terminal on the battery adjacent to the main one. That control's the cylinder position on start and after, I clean up the wiring and now she runs tit's. check engine light cleared it self after 3 starts.
Pedo-Bear Approved!
GNARKILL is offline
