How long does the Thermostat last? - Team Integra Forums - Team Integra
post #1 of 20 (permalink) Old 11-06-2006, 12:05 PM Thread Starter
Whould ant one happen to know how many miles a thermostat lasts? Mine has been in my car for about four years.
There are two types of people in the world. Those who build horsepower and those buy it. Which one are you? '87 Honda Prelude SI...RIP
eaglemhf is offline
post #2 of 20 (permalink) Old 11-06-2006, 12:10 PM
Don't think miles has alot to do with it, it's thermocycles, which is impossible to know. The original thermostat in my Nissan was 12 years old when I replaced it and I only did that when I was troubleshooting for an old radiator, it was probably still good. If it's still functioning, leave it alone.
mrmad is offline
post #3 of 20 (permalink) Old 11-06-2006, 12:14 PM
post #4 of 20 (permalink) Old 11-06-2006, 12:23 PM
Articles: 2
Feedback Score: 21 reviews
If you keep your fluid clean, use distilled water and a lube in the water, they can last like Casey said.
Harness is on it's way back...wrong harness...I'll be finding out WTF is going on with it. 2a or what??
jojo is offline
post #5 of 20 (permalink) Old 11-06-2006, 12:31 PM
Articles: 11
lasted for over 10 years on my g2 before i need to replace it, the one on my 99 g3 is still functioning.
codenamezero is offline
post #6 of 20 (permalink) Old 11-06-2006, 12:54 PM Thread Starter
Why I ask is last weekend I was driving from D.C. and my temp rose pasted half way and I had to turn on my heater to get it to go back down.
eaglemhf is offline
post #7 of 20 (permalink) Old 11-06-2006, 12:58 PM
Articles: 11
check if your fluid level if is good, check and see if your rad crack or something... flush the fluid, if it still happen, time to replace the thermostat.
post #8 of 20 (permalink) Old 11-06-2006, 01:03 PM
Since this ios a thermo topic. I wanted to side bust in with a question. If the thermo fails, is it possible for my heater to fail? I replaced my radiator abaout three monthes ago and i always get a "cooler" than normal reading
That was like one clean chunk!
95scteg is offline
post #9 of 20 (permalink) Old 11-06-2006, 01:19 PM Thread Starter
The heater would not fail...it would recieve coolant by the smaller hose. I think your coolant level could be low if the heater core is blowing cool air of it's block. Did you turn the heater on full heat when you changed the coolant?
eaglemhf is offline
post #10 of 20 (permalink) Old 11-06-2006, 01:40 PM
IOf your heater is not working it is likely that your radiator (not the resevior) is low on coolant. Could also be a waterpump
mrmad is offline
post #11 of 20 (permalink) Old 11-06-2006, 03:02 PM
During cold temps (now through winter, early spring) my temperature gauge never really goes much futher past that solid white \ (slash) mark. If I let the car sit & idle, it will eventually go up to normal (just left of center) but once i start to drive again it'll go back down. To me it sounds like it's stuck open but I'm not sure...any input would be helpful, sorry for the thread jack
Shamash
JonDubya is offline
post #12 of 20 (permalink) Old 11-06-2006, 04:23 PM
malfunctioning thermostat. My car did the same thing a while back. I ended up replacing the thermostat, it's normal now.
Thermostats have random life spans, similar to a lot of electronic devices or radioactive decay, which means it could fail anytime or last forever. It's like in any day of its life the probability of its failure is 0.001, independent on its past. In general, this possibilty is small, so thermostats last long time.
(from Physics class)
Go Bears!
phantuan is offline
post #13 of 20 (permalink) Old 11-06-2006, 05:29 PM
Thx...and uh, radioactive decay, or half lives, are fixed values...varying only between different material.
JonDubya is offline
post #14 of 20 (permalink) Old 11-06-2006, 07:58 PM
What do you mean it's a fixed value? radioactive decay is a process. I was comparing life of a thermostat to that of a atomic nuclei in the process which is impossible to predict because it's random, independent on its past.
A 10 year old thermostat is as good as a brand new one.
A brand new thermostat can stop working properly the next day.
phantuan is offline
